7 members (fonz8261, Shaffer's1950, tclederman, Hotrod Lincoln, Bill Hanlon, Charles in CA, 49choptop),
74
Mod | | | Forums66 Topics128,087 Posts1,056,376 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | What type of hydraulic fluid do I need to top off my harbor freight shop crane. "8ton ram" I blew out a seal and had to replace lost some of the hydraulic fluid and need to add more.
Thanks | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Focus,
The VERY easiest drill would be to go to your FLAPS and pick up a quart of "jack oil"! It will be a generic hydraulic oil and will undoubtedly be compatible with the oil in your HF crane.
If you want to be technical, any AW-32 hydraulic oil would do....even ATF would work! Because there isn't a powered pump involved, the system is very forgiving.
I hope the hoist didn't have a brand new engine hanging from the hook when it blew its brains!
Stuart | | | | | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | Thanks Stuart No I was lifting a cedar log to take to the sawmill for lumber to make the top of a padio table when it blew guess was a little to much. But after six months waiting on seal parts from HF I am ready to use it on the 59 truck. Barry | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I always use ATF, oil is oil to me-ATF is prettier when it spills all over the floor | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I use Napa hydraulic jack oil in my HF jack, works fine.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | While hydralic oil is probably better, most any oil you use will work. | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Harbor Freight sells hydralic jack oil also. | | |
