6 members (Phak1, Bill Hanlon, Greg_H, dt235sd, Jon G, Oswald), 131 guests, and 2 robots.
Topics128,090
Posts1,056,384
Members48,442
What type of hydraulic fluid do I need to top off my harbor freight shop crane. "8ton ram"
I blew out a seal and had to replace lost some of the hydraulic fluid and need to add more.
Focus,
The VERY easiest drill would be to go to your FLAPS and pick up a quart of "jack oil"! It will be a generic hydraulic oil and will undoubtedly be compatible with the oil in your HF crane.
If you want to be technical, any AW-32 hydraulic oil would do....even ATF would work! Because there isn't a powered pump involved, the system is very forgiving.
I hope the hoist didn't have a brand new engine hanging from the hook when it blew its brains!
Stuart
Thanks Stuart
No I was lifting a cedar log to take to the sawmill for lumber to make the top of a padio table when it blew guess was a little to much.
But after six months waiting on seal parts from
HF I am ready to use it on the 59 truck.
Barry
I always use ATF, oil is oil to me-ATF is prettier when it spills all over the floor
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I use Napa hydraulic jack oil in my HF jack, works fine.
Paint & Body Shop moderator
While hydralic oil is probably better, most any oil you use will work.
Harbor Freight sells hydralic jack oil also.
Moderated by  MNSmith
