3 members (RLB, 1955 1 Series, Peggy M), 101 guests, and 1 robot.
Topics128,105
Posts1,056,542
Members48,448
U
U Offline
I'm getting very close to completing my wiring project and found this voltage reducer in my harness box with other wiring items. Not positive, but I think it's for the 6v heater fan? I'm not sure what the amp rating is on the stock motor. I do have the setup with a second motor for the defroster. I'm not connecting those right now, but would like to down the road. Do I need two separate voltage reducers - one for each motor? Do I need multiple reducers for each?
FYI - I did add a different type of reducer for the fuel gauge.
~ John in Utah
Here We Go
Follow in his DITY Bay
Four of these resistors (6 ohm) wired in parallel will do the same thing as the "voltage reducer" in your pic- - - -and their 100 watt rating will be at least as durable as the one you have. They will give a total of 1.5 Ohms of resistance, and can handle up to 400 watts of load since there are four paths for the current to flow.
www.ebay.com/itm/372308315193
