7 members (Charles in CA, LAROKE, Wally / Montana, Cletus1950, 78buckshot, TrknGMC, UtahYork), 162 guests, and 5 robots.
Topics128,107
Posts1,056,221
Members48,436
#1597752 02/14/2026 12:45 AM
Hi all
I’m looking for some inner front wheel bearings for a 1.5 ton truck. The original bearings are Timken brand # 25583 for the cone and #25519 for the cup
Any one have any ideas on an alternate? Or a bearing shop that might be able to source these for a reasonable cost
Look at page #168 of the Timken roller bearing progressive size chart and find a bearing with similar inside and outside dimensions. You might need to machine the hub to fit a cone/cup part number with similar outside dimensions or cup width. There are several bearings listed there with the same 1.75" inside diameter.
www.timken.com/wp-content/uploads/2025/11/Timken-Tapered-Roller-Bearing-Catalog_10481.pdf
Don - There are currently two of each of the cones and cups offered by the same ebay seller at the links below. Dirt cheap as compared to the crazy prices others are asking for bearings you may have to order and wait for.
Timken bearing cone #25583 says has two on hand to offer at $44.95 OBO each + $9.46 shipping
Timken bearing cup #25519 says also two on hand at $24.95 OBO each + $9.46 shippng
You could probably get them all and limit shipping costs if they will dicker with you.
Good luck! thumbs_up
~ Dan
1951 Chevy 3 window 3100
Thanks for the info
I checked eBay and there were two cones and cups available and I was able to purchase them.
Thanks Jerry
I just happens to check eBay and darned if there wasn’t some available I was able to purchase them.
Now I think I’m on a roll. Tires next then hopefully I can get my beast running.
Don - Glad you were able to secure those bearings! Looking forward to your next update on your project! smile
~ Dan
