| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2025 Posts: 17 'Bolter | | 'Bolter Joined: Dec 2025 Posts: 17 | Hi all I’m looking for some inner front wheel bearings for a 1.5 ton truck. The original bearings are Timken brand # 25583 for the cone and #25519 for the cup Any one have any ideas on an alternate? Or a bearing shop that might be able to source these for a reasonable cost Thanks | | | | | Joined: Feb 2004 Posts: 29,743 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,743 | Look at page #168 of the Timken roller bearing progressive size chart and find a bearing with similar inside and outside dimensions. You might need to machine the hub to fit a cone/cup part number with similar outside dimensions or cup width. There are several bearings listed there with the same 1.75" inside diameter. www.timken.com/wp-content/uploads/2025/11/Timken-Tapered-Roller-Bearing-Catalog_10481.pdfJerry
| | | | | Joined: Sep 2009 Posts: 5,775 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,775 | Don - There are currently two of each of the cones and cups offered by the same ebay seller at the links below. Dirt cheap as compared to the crazy prices others are asking for bearings you may have to order and wait for. Timken bearing cone #25583 says has two on hand to offer at $44.95 OBO each + $9.46 shipping Timken bearing cup #25519 says also two on hand at $24.95 OBO each + $9.46 shippng You could probably get them all and limit shipping costs if they will dicker with you. Good luck!
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Dec 2025 Posts: 17 'Bolter | | 'Bolter Joined: Dec 2025 Posts: 17 | Thanks for the info I checked eBay and there were two cones and cups available and I was able to purchase them. | | | | | Joined: Dec 2025 Posts: 17 'Bolter | | 'Bolter Joined: Dec 2025 Posts: 17 | Thanks Jerry I just happens to check eBay and darned if there wasn’t some available I was able to purchase them. Now I think I’m on a roll. Tires next then hopefully I can get my beast running. | | | | | Joined: Sep 2009 Posts: 5,775 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,775 | Don - Glad you were able to secure those bearings! Looking forward to your next update on your project!
