4 members (TUTS 59, jmoore, 66flea, Ponchogl), 113 guests, and 3 robots.
Topics128,127
Posts1,056,681
Members48,452
#1597498 02/10/2026 4:54 AM
51 GMC 250-22 H072. Manual calls for 90w gear oil. I believe it has a GL1 rating. Has anyone used 80-90 or 85-90 and if so , comments? Thanks
O Online: Content
The factory actually specifies 90w mineral oil (page 0-5 of the 1948-1952 Chevrolet Truck Shop Manual).
Go to Tractor Supply or a similar store and purchase 90weight mineral oil. It's sold as Ford Tractor Transmission Fluid.
https://www.tractorsupply.com/tsc/product/traveller-ford-tractor-hydraulic-oil-2-gal-t806600-1636284
1950 Chevrolet 3100 (Ol' Roy)
Agree with Otto. 90w mineral oil
Craig
For the differential you should use a GL-5 oil. It’s an EP (Extreme Pressure) lubricant that protects the hypoid gears. I use Lucas 80/90. And for the transmission you can use 90 weight mineral oil or a GL-4 oil. Do not use a GL-5 oil in the transmission, it has a high concentration of sulfur/phosphorus additives that can corrode yellow metals like bronze, copper and brass synchronizers.
Below attachment is from the 1948 - 1951 Chevrolet Truck Shop Manual.
