3 members (moparguy, texas46, Gray_Ghost), 191 guests, and 3 robots.
Topics128,108
Posts1,056,236
Members48,437
#1596867 01/31/2026 4:27 AM
I have a '59 261 with a 350 mounted behind it using an adapter plate. This is a project I inherited when my dad passed away. Problem is that a starter was taken off of it when he was well and working on it but I do not have it any more. Does anyone know what model GM vehicle would be the most likely to have the starter that would fit this kind of application/setup? I remember seeing it some LONG time ago and it seemed like that starter looked like one I used on Olds Cutlasses back in the 80's. Pretty sure this has a standard 168-tooth flywheel.
I would suggest that you post a picture of the adapter plate and that may generate some
suggestions. A 261 would have a 2 bolt starter that bolted to the bellhousing. V8 starters
also bolted to the bellhousing with 3 bolts in that era. Later engines with automatic
transmissions usually mounted to the engine.
Fred
Sounds like this will be a 2-bolt offset starter that mounts to the engine block, but most FLAPS will want an actual model for the application. The 261 came out of a larger truck and is either a '59 or '60 model. I will probably call it a 1960 model truck with automatic and see where that goes.
If it was me, I’d count the flywheel teeth and take a picture so you know if it’s a 6V or a 12v inline 6 starter before you start buying parts and hearing grinding. There is a difference in # of teeth and the pitch of the teeth. I’d have to go look it up in my book to give you the exact #s.
I only say this because my 261 had a 6V flywheel behind it. You never know what previous owners changed.
Chris
What Chris said.
Check this Tech Tip for Starter and Flywheel Identification
I also had a 1958 235 that had a 6 volt flywheel on it.
The bellhousing bolt pattern between a 261 six and a TH 350 automatic are completely different, so an aftermarket adapter plate will have to be used. Most likely, the adapter will have some sort of mounting flange for a starter. You'll probably need to post some pictures of the engine/trans assembly before we can make an educated guess about which starter will fit. You're also going to need a modified flex plate instead of a flywheel, because stovebolt engines only ran Powerglide or Hydra-Matic transmissions- - - -never a TH 350. 235/261 engines do not have any provision to bolt a starter to the block. Early small block V8s had a starter with a 3-bolt nose cone that bolted into the bellhousing. Something like that would probably be the best choice to fit to a stovebolt/350 setup.
Just an added suggestion, but who manufactured/sold the adpater plate for your 261 to Turbo 350 match up??? They would be the one to reach out to for a starter suggestion IMHO.
~ Dan
1951 Chevy 3 window 3100
