| | | Forums66 Topics128,086 Posts1,056,101 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 48 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 48 | I have a '59 261 with a 350 mounted behind it using an adapter plate. This is a project I inherited when my dad passed away. Problem is that a starter was taken off of it when he was well and working on it but I do not have it any more. Does anyone know what model GM vehicle would be the most likely to have the starter that would fit this kind of application/setup? I remember seeing it some LONG time ago and it seemed like that starter looked like one I used on Olds Cutlasses back in the 80's. Pretty sure this has a standard 168-tooth flywheel. | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | I would suggest that you post a picture of the adapter plate and that may generate some suggestions. A 261 would have a 2 bolt starter that bolted to the bellhousing. V8 starters also bolted to the bellhousing with 3 bolts in that era. Later engines with automatic transmissions usually mounted to the engine. Fred
| | | | | Joined: Oct 2008 Posts: 48 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 48 | Sounds like this will be a 2-bolt offset starter that mounts to the engine block, but most FLAPS will want an actual model for the application. The 261 came out of a larger truck and is either a '59 or '60 model. I will probably call it a 1960 model truck with automatic and see where that goes. | | | | | Joined: Jan 2013 Posts: 2,234 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,234 | If it was me, I’d count the flywheel teeth and take a picture so you know if it’s a 6V or a 12v inline 6 starter before you start buying parts and hearing grinding. There is a difference in # of teeth and the pitch of the teeth. I’d have to go look it up in my book to give you the exact #s.
I only say this because my 261 had a 6V flywheel behind it. You never know what previous owners changed. Chris
| | | | | Joined: May 2015 Posts: 11,065 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,065 | What Chris said. Check this Tech Tip for Starter and Flywheel IdentificationI also had a 1958 235 that had a 6 volt flywheel on it.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | The bellhousing bolt pattern between a 261 six and a TH 350 automatic are completely different, so an aftermarket adapter plate will have to be used. Most likely, the adapter will have some sort of mounting flange for a starter. You'll probably need to post some pictures of the engine/trans assembly before we can make an educated guess about which starter will fit. You're also going to need a modified flex plate instead of a flywheel, because stovebolt engines only ran Powerglide or Hydra-Matic transmissions- - - -never a TH 350. 235/261 engines do not have any provision to bolt a starter to the block. Early small block V8s had a starter with a 3-bolt nose cone that bolted into the bellhousing. Something like that would probably be the best choice to fit to a stovebolt/350 setup. Jerry
| | | | | Joined: Sep 2009 Posts: 5,868 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,868 | Just an added suggestion, but who manufactured/sold the adpater plate for your 261 to Turbo 350 match up??? They would be the one to reach out to for a starter suggestion IMHO.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
