Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (farmallb, Lostbuthaulinass, Bill Hanlon, TexasJim50), 40 guests, and 4 robots.
Topics128,010
Posts1,055,251
Members48,418
#1597009 02/02/2026 8:04 PM
It’s cold outside but I decided to try to check my compression Chevy IL 6. After pulling the plugs & removing the valve cover I realized I find have any way to turn the motor. The flywheel up front does not have a nut on it so I can’t go that way.
I’ll get a remote starter & try that.
I think the # 2 cylinder is at TDC & the rockers are loose so I assume this is where I should do the test.?
It holds no pressure but I can’t tell where it’s going. Help!
1953 Chevy 153A 3/4-ton
Working on my project since 2015
Follow along in my DITY
That engine most likely has hydraulic lifters. Loose rockers indicate something is stuck, (like valve stems in the guides) or the rockers are way out of adjustment. Even with both valves fully closed, there shouldn't be any looseness between the rockers and the valve stems.
Are you trying to perform a compression test or a cylinder leakage test?
BC
1960 C60 pasture art
A cylinder leakage test. I’m just trying to find out if the rings are bad or the head has a problem. It blows smoke when I release the gas after revving & it uses oil.
I did adjust the valves myself after I put the head on the motor. Right now the #2 appears to be on compression stroke & the cylinder is up. The rockers are up & I can jiggle them, so they are loose. Problem is that I can’t turn the motor by hand.
With all the spark plugs out and transmission in neutral, you should be able to turn the engine using the fan blade. What year engine do you have? Those rockers look like the ones used on the SBC V-8's that get adjusted at the rocker studs. I don't know when GM went to that style rockers on the 6 cylinders. Likely after 1958 as I had a 235 with rocker shafts.
B Online: Content
The 235 with rockers mounted on a shaft was used through the 1962 models. In 63 the engine was a 230 cubic inch model that used the individually mounted rockers.
Put the transmission in high gear and slowly roll the truck forward. Set the parking brake firmly before pressurizing a cylinder. Search the forum archives for "companion cylinder valve adjustment" to get each cylinder on TDC of its compression stroke.
I believe this is a 1972 ish model. I think the Nova & Camaro used it.
I did the simple valve lashing technique when the motor was out. The harmonic balancer has 3 threaded holes in it that I used bolts to turned the motor using a pry bar. It’s a bit tighter being in the truck but hopefully I can do that. My memory is coming back now. So now I only want to do the pressure test then go from there.
Oh, the fan belt is not tight enough to be able to use it to turn the motor.
Tighten that sucker up a bit. A v-belt will grip pretty well if tight enough. Readjust the belt tension after you're done.
Nothing is simple to do. I had to remove the alternator to remove the brace. I had to cut the hole in it longer in order to tighten the belt. After tightening it I could turn the motor with the fan but not good. Still not tight enough I guess.
I neglected to remove the battery cable & grounded the alternator (big spark). Ruined it!
I did adjust two valves used that lashing technique again.
So while checking cylinder compression m, air leaks out pretty bad somewhere. It must be in the head, I don’t feel air from the oil dip stick.
Just to see if a valve was not closed fully I released the rockers fully so the valves should be closed. It still leaked down but not as loud.
Is there anything I can do other than take the head in for service??
Listen at the carburetor and the tailpipe. It's possible you've got a burned valve or a carboned-up valve seat. Have you considered installing a slightly shorter belt instead of metal butchering?
I have no idea what belt that is Jerry?
That head was serviced before I put it on. Best I remember he didn’t do anything special to it. I just remember it had fresh grease in contact points at the rockers & rods. I have about 700 miles on it & I ran ethanol free gas most of the time.
I honestly could not tell where the leak sound came from.
The motor runs great.
1 Offline
As Jerry suggested, change the belt. Pull the old one and take it to your auto parts house and they should be able to measure and replace it. I would get two belts, one the same size and one the next smaller size. Your present belt is probably stretched and worn and the same size is probably the correct one. If you are lucky, the part number may still be visible on the belt.
I have to replace the alternator anyway so replacing the belt is no problem.thanks.
7
7 Offline
My opinion is if the engine runs well, plugs are not fouling with oil, and it only smokes while decelerating, it probably is a valve stem/seal/guide issue.
Great! Tell me more good news. On this head, can I replace them myself or will I have to pull the head or have someone do it for me?
Does Rislone valve seal repair oil work??
