0 members (),
81
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2021 Posts: 87 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 87 | Folks, got a 216 stovebolt with 3 spd transmission torque tube rear, gearbox has a crack and leaks, differential also leaks, all original engine/transmission/diff to the ute.
I have a 55 open drive diff in my shed for a conversion to open drive
Does anyone know what’s involved in fitting the Packard 35-37 3 speed up to my engine, been told it was a common conversion back in the day
Steve
Last edited by Gdads51; 01/19/2026 3:40 PM. Reason: add detail to title to help with information search
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | I can't imagine how many 35-37 Packard transmissions there are still left in captivity but it's unlikely it would be a bolt in. Things to consider would be having the clutch gear the same length and have the same spline as your existing clutch. Would the mounting for the transmission to the bellhousing be similar. Also what type of output shaft would be needed. What other fabrication and or machining would be involved. It sounds like a lot of work and expense for minimal gain. Fred
| | | | | Joined: Sep 2009 Posts: 6,056 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,056 | Simso - Here's a 2005 discussion in the HAMB forum that mentions some folks using the 35-37 Packard 3 speeds behind a couple different engines. A couple mentioned were specifically Stovebolt 6 engines and one detailed some info about the fabrication/use of an adapter plate. I found it using the web search "1935-37 Packard 3 speed transmission". You might find more on the subject in a search of your own.  Hope this might be of some help.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | I have a 270 GMC with a Packard transmission behind it. It uses an adapter plate. These adapters were sold 70 years ago, but it would be difficult to find one now. But a machine shop could build one. | | | | | Joined: Oct 2021 Posts: 6,970 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,970 | Johnny Cash's famous A-dapter kit!
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2021 Posts: 87 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 87 | Thanks for the link, I actually google searched before posting, maybe here in Australia some pages get excluded from searches, very informative link | | | | | Joined: Sep 2019 Posts: 167 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 167 | Thanks for the info on this match up. I can’t imagine that there would be much difference between the’37 and’40 Packard transmissions.
I invest my money in precious metals, mostly rust!
