1 members (LAROKE), 127 guests, and 2 robots.
Topics128,196
Posts1,057,393
Members48,471
I'm working on a 1950 panel and not ready yet, but thinking ahead about paint. Tried to find info with search - no luck. Someone have idea if one gallon of acrylic enamel will get the exterior done? Thanks for any help.
Life is good on Windy Ridge!
AD Addict & Tinkerer
I just bought 1–1/2 gallons of single stage paint for my 52 3100, and it will just be enough. I also painted the interior with the same paint. I would think a panel (minus the interior) would take as much or a bit more.
You don’t want to run out of paint in the middle of the job and take the chance of mismatched colors. You may also want a bit extra for mistakes and future repairs.
Phil
Project Journals
Stovebolt Gallery Forum
I used a gallon and a quart for my 3100 pickup and have just a dab left. There's no way I'd consider painting my interior Omaha Orange. LOL!
I would imagine that 1-1/2 gallons would be enough for the exterior of a panel, like Phil said.
Also, don't buy the paint real early, as some paint has a shelf life.
Depends on how torn down your project is. If you are doing jams, trim, pieces and parts off the vehicle, etc. I've estimated 1-1/2 gallons for my Suburban, so I'm going to buy 2 gallons for the job.
Moderator, Electrical Bay
I'm going to jump in with Mark and say 2 gal to be safe. Not knowing what sort of sprayer, etc you have it isn't easy at all to say but 1 gallon probably won't do it unless you can paint with almost no overspray. Also please keep in mind you may have wheels, front apron pieces, etc to paint also and I don't know if you're painting running boards to match or not. Plus there's a chance you might have to re-do something...a fender, door, etc. Good luck!
~ Jon
Ditto on "all the above". If you're doing the firewall, the door jambs, and all the peripheral bits and pieces, you're going to use up quite a bit of paint. Also be sure to use the proper reducer. It's going to be temperature-sensitive, so unless you're doing all the painting at once, you might need to use more than one type of reducer. Just a few degrees of temperature change can have a big influence on the type of reducer you'll need.
Thanks for all the responses!! I will be doing the fender edges and door jambs so it sounds like another gallon. I have interior paint in the factory gray color for panels so that will eliminate some of the outside color usage. Thanks again - Jay Self
