| | | Forums66 Topics128,196 Posts1,057,388 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 26 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 26 | I'm working on a 1950 panel and not ready yet, but thinking ahead about paint. Tried to find info with search - no luck. Someone have idea if one gallon of acrylic enamel will get the exterior done? Thanks for any help.
Life is good on Windy Ridge!
| | | | | Joined: Feb 2019 Posts: 4,515 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,515 | I just bought 1–1/2 gallons of single stage paint for my 52 3100, and it will just be enough. I also painted the interior with the same paint. I would think a panel (minus the interior) would take as much or a bit more.
You don’t want to run out of paint in the middle of the job and take the chance of mismatched colors. You may also want a bit extra for mistakes and future repairs.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: May 2015 Posts: 11,185 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,185 | I used a gallon and a quart for my 3100 pickup and have just a dab left. There's no way I'd consider painting my interior Omaha Orange. LOL!
I would imagine that 1-1/2 gallons would be enough for the exterior of a panel, like Phil said.
Also, don't buy the paint real early, as some paint has a shelf life.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | Depends on how torn down your project is. If you are doing jams, trim, pieces and parts off the vehicle, etc. I've estimated 1-1/2 gallons for my Suburban, so I'm going to buy 2 gallons for the job. | | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | I'm going to jump in with Mark and say 2 gal to be safe. Not knowing what sort of sprayer, etc you have it isn't easy at all to say but 1 gallon probably won't do it unless you can paint with almost no overspray. Also please keep in mind you may have wheels, front apron pieces, etc to paint also and I don't know if you're painting running boards to match or not. Plus there's a chance you might have to re-do something...a fender, door, etc. Good luck!
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | Ditto on "all the above". If you're doing the firewall, the door jambs, and all the peripheral bits and pieces, you're going to use up quite a bit of paint. Also be sure to use the proper reducer. It's going to be temperature-sensitive, so unless you're doing all the painting at once, you might need to use more than one type of reducer. Just a few degrees of temperature change can have a big influence on the type of reducer you'll need. Jerry
| | | | | Joined: Dec 2013 Posts: 26 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 26 | Thanks for all the responses!! I will be doing the fender edges and door jambs so it sounds like another gallon. I have interior paint in the factory gray color for panels so that will eliminate some of the outside color usage. Thanks again - Jay Self
