3 members (DadsFirstPickup, 68ironhead, 1955 1 Series), 104 guests, and 2 robots.
Topics128,093
Posts1,056,480
Members48,444
#1596084 01/15/2026 11:30 PM
JD1
Offline
I noticed my temperature gauge wasn't registering the last time I had the truck out in the fall.
It's a mechanical gauge, so I thought it works or it doesn't. When the outside temperature warms up in the spring, I'll have to inspect the line to see if something is broken.
Would coolant level affect the gauge or do I need to replace it?
JD
1951 Chevy 3100 1/2 ton (1957 235, 4 speed, 411 rear)
Moderator, Electrical Bay
Coolant level won't affect the gauge and you are right...it either works or doesn't. I had mine rebuilt and recalibrated about 50 years ago. I am not sure who could do that today...hopefully for you there is somebody locally that knows how.
~ Jon
You might try this company for a rebuild:
Temp sending units, coils, fuel sending units, tube radios, vacuum advance, voltage regs. 1920s to 1970s (mostly 30s, 40s, 50s)
Atwater Kent
12 Jacques Street Worcester,
MA, 01603
(508)792-9500
http://www.mykmlifestyle.com
Or one of these:
Then and Now Automotive
447 Washington St
Weymouth, Ma 02188
Ph: 781.335.8860
Fax: 781.335.1925
https://www.then-now-auto.com/
Instrument, clock, gauge restoration, fuel tank sending unit rebuilding service
Instrument Services, Inc.
11765 Main Street
Roscoe, IL 61073
800.558.2674
http://clocksandgauges.com/
1950 Chevrolet 3100 (Ol' Roy)
JD1
Offline
Thanks guys. Waiting for the weather to turn to spring here in PA.
7
7 Offline
Life can't wait! get out there and work on her and take it out in the snow to play!
JD - If you want to, you can also just purchase a reproduction gauge from one of our various well known vendors.
Classic Parts offers Part # 24-703C for 6 cylinders or Part # 24-703D for 8 cylinder engines. Both are currently in stock.
Pretty reasonable cost for either at just under $60 + shipping.
~ Dan
1951 Chevy 3 window 3100
J Online: Content
Coolant must be in contact with the bulb, or you will not get an accurate reading. It will show some heat, but it won't be correct.
JD1
Offline
I bought an entire new gauge assembly from Classic Parts when I restored the interior a few years ago. I'm pretty sure the temp gauge was working when I installed it but not sure. I'll have to check the coolant level in the spring. The snow is finally melting here in PA.
A quick way to test the gauge would be a one-burner propane camp stove sitting on the intake manifold, a pan of water, and submerge the sending bulb in the hot water. The bulb doesn't care if it's actually in the engine or not, and you wouldn't even have to remove it from the truck.
B Online: Content
... or unscrew the sending bulb from the head and then get a pot of water boiling on the kitchen stove. Take the pot to the car along with a cooking or meat thermometer. Immerse the bulb and the thermometer and compare as the water cools off.
