| | | Forums66 Topics128,191 Posts1,057,224 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2025 Posts: 8 'Bolter | | 'Bolter Joined: Dec 2025 Posts: 8 | I am redoing my entire brake system and got a new master cylinder. I am using the old tee block that attaches to the back. The question I have, is there supposed to be a copper ring between the master cylinder and the tee block? Seems like there should be but wanted to check. Didn’t remember one on there when I took the tee off the old master cylinder. | | | | | Joined: Feb 2016 Posts: 1,995 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,995 | If there is no other type of sealing surface such as a flare or O-ring or tapered pipe threads, then you probably need the copper gaskets.
| | | | | Joined: Jul 2020 Posts: 51 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 51 | Yes you need the copper ring gasket. Did my 53 last year and rings came with the parts. | | | | | Joined: Dec 2025 Posts: 8 'Bolter | | 'Bolter Joined: Dec 2025 Posts: 8 | | | | | | Joined: Feb 2004 Posts: 29,876 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,876 | I believe there needs to be a copper gasket on both sides of the tee block. Jerry
