6 members (Joe H, Hanks custodian, dt235sd, Chris's 46 / 515, carbking, Goach2), 70 guests, and 6 robots.
Topics128,188
Posts1,057,216
Members48,465
I am redoing my entire brake system and got a new master cylinder. I am using the old tee block that attaches to the back. The question I have, is there supposed to be a copper ring between the master cylinder and the tee block? Seems like there should be but wanted to check. Didn’t remember one on there when I took the tee off the old master cylinder.
7
7 Offline
If there is no other type of sealing surface such as a flare or O-ring or tapered pipe threads, then you probably need the copper gaskets.
Yes you need the copper ring gasket. Did my 53 last year and rings came with the parts.
Awesome, thanks all!
I believe there needs to be a copper gasket on both sides of the tee block.
