4 members (Samantha, Hanks custodian, mk72, 1955 1 Series), 77 guests, and 2 robots.
Topics128,186
Posts1,057,315
Members48,469
Moderated
Moderated
New member from the Rochester NY area. Picked up a 52 and a 54 Chevy 3100 that have been stored in an old barn for at least 20 years and am starting to dig in to them. Dealing with no keys and the typical problems for trucks sitting that long but both are in surprisingly good condition. Short term plan is to get them both running and get a better feel for them. Long term is to get one to a stock condition with some modern safety features and potentially drop a V8 in the other.
A definite plus on this is most of my wife's family has worked for Chevy/GM for decades so she's fully on board. Unfortunately, she's also getting the cart ahead of the horse and planning on what color "her" truck will be.
Looking forward to any help and advice I'll need along the way.
Very nice trucks ,lots of imfo on here and a lot of members who will help with your questions.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
You can bypass the ignition switch with a simple toggle switch from Ace Hardware.
You're a long way from turning them over, though. Make sure the valves aren't stuck from varnished up gasoline. Don't even think about putting fresh gas in the fuel tanks when the time comes. Use new gas from an gas can and a hose to the fuel pump.
They at least look to be in decent cosmetic shape.
1950 Chevrolet 3100 (Ol' Roy)
Welcome to the ‘bolt. Very nice finds. Definitely get them safe to drive, then drive them!!
Please ask questions specific to a particular problem in the appropriate forums to get the best responses.
Another quality post.
Real Trucks Rattle
Welcome to Stovebolt Paddy! wave Looks like a couple of nice finds. The '52 looks to have a home made platform/stake bed set up, something not often seen. Both look like good candidates for your plans and looking forward to seeing and hearing more on them. thumbs_up
If you haven't already, read through this Welcome - and now where do you go?? thread as it will help you focus and seek advice in the most "appropriate forums" as mentioned by Rusty Rod. wink
~ Dan
1951 Chevy 3 window 3100
Former Workshop Owner
Okay, which one is Hers? 😁 Inquiring minds, we gotta know.
Welcome, glad you found us.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Welcome!
From the looks of your pictures, you may not need to repaint either one of them. Clean them up good and throw a coat of wax on them and I'll bet they will both look pretty good! After you get them running, of course. Keep us posted on your progress.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Moderated
Moderated
That's the problem, John, she hasn't decided.
If she gets the 3 on the tree pattern down, it's probably safest to keep her lead foot in whichever one remains stock.
Welcome to Stovebolt. You’ve got two nice looking trucks. Nice score!
1950 3100w/63K
Farm Truck: Fame-up restoration / modification
Follow the restoration story in his Project Journal
1950 Styleline Deluxe Coupe w/93K
AD Addict & Tinkerer
First, welcome to the ‘Bolt! Nice find on your trucks. Both look to be in real good shape for the start of your “His and Her” projects.
Congratulations!
While she makes up your mind, one piece of advice I can give you, is if the trucks have not run in awhile, DO NOT ATTEMPT TO START EITHER TRUCKS WITH THE EXISTING GAS IN THE TANKS”. Doing so will cause the valves to stick and potentially cause catastrophic failure. Far too many ‘bolters in this forum have experienced this first hand. Either replace the tank and lines, clean them out, or use a temporary tank to hear your engine(s) run.
Again, welcome to the ‘Bolt!
Phil
Project Journals
Stovebolt Gallery Forum
What he said. Been there, done that!
Rich
1947 Loadmaster
