Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Southerntruck, baldeagle), 40 guests, and 2 robots.
Topics128,005
Posts1,055,264
Members48,418
#1595192 01/01/2026 6:10 PM
56, 3100, 235 Was there a single cable or two cables, ground terminal to frame and/or ground terminal to motor? Looking for what it was from factory.
1956 3100 three speed 6 cyl. Stock with a few upgrades.
7
7 Offline
My '57 LCF has a braided strap from the battery to the firewall behind the battery, and another from the lower part of the firewall/toeboard to the bellhousing at one of the starter bolts. Mine is a factory 283 V8. I have kept those straps in their original locations and also added a conventional stranded cable from the battery to a water pump bolt.
I have ground going from starter /bell housing to toe wall and battery.
Both strap and battery cable. 4awg
Strap from the battery to the upper firewall. I added a battery cable from the breather tube mount on the block
to the frame of the truck From the frame to the bell housing. Never too much ground.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Chevy used the "baby chicken" theory with those short braided ground straps- - - -"CHEEP- - - -CHEEP- - - -CHEEP!" It was a lot less expensive on the assembly line that way. Anytime another connection is added into a heavy current circuit there's a potential for loose connections or corrosion to happen. If you're building a "numbers-correct" show truck stick with the original stuff. Otherwise, run a piece of #0 welding cable for a ground from the battery to the engine block or the bell housing to carry starter current, and use smaller grounds to the body and frame for lights, ignition, generator/alternator, etc.
