6 members (SmalltownTRKGuy, Otto Skorzeny, moparguy, Gdads51, dt235sd, 1 invisible), 76 guests, and 4 robots.
Topics128,094
Posts1,056,056
Members48,433
What is the best way to clean up the rust inside of the top of the '47-'53 bed where it forms pretty much a pipe.
I was thinking along the lines of a steel brush with 1 5/8" diameter attached to a 6 1/2' long rod chucked in a drill.
What say you?
Sounds like a good plan to me. Maybe follow up with some phospo ospho sprayed into the space.
I had a blaster do my bedsides, but I'm sure they didn't get carried away with the inside of the rail. I had them shoot them with epoxy primer as well.
Insomniac
Insomniac
There used to be a business here with a big tank where large objects could be submerged in a solution that removed the rust. They could handle a whole car body. They did my cab. They are no longer here, but maybe there's a facility in your area?
Gord 🇨🇦
1954 1/2 ton 235 4 speed
What the prior post said, I have an ongoing street rod project (32 Ford pickup) and drove from K.C. Mo. area to Topeka, Ks. to a company that does commercial plating of large industrial objects (light poles and such). They had a dip tank large enough for a car body. I had them do my bed sides to get inside the rolled areas at the bed tops. Very reasonable pricing. Probably something like that around your area within driving distance.
I found a 1 3/4" diameter pipe brush at Grainger for $15. I'll give that a go, then treat it with ospho and run the brush back through after 24 hours to clean up the chalky residue from the chemical process. I will then go to the blaster and have it epoxy primed and painted.
