| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | What is the best way to clean up the rust inside of the top of the '47-'53 bed where it forms pretty much a pipe. I was thinking along the lines of a steel brush with 1 5/8" diameter attached to a 6 1/2' long rod chucked in a drill. What say you?
| | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | Sounds like a good plan to me. Maybe follow up with some phospo ospho sprayed into the space.
I had a blaster do my bedsides, but I'm sure they didn't get carried away with the inside of the rail. I had them shoot them with epoxy primer as well.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | There used to be a business here with a big tank where large objects could be submerged in a solution that removed the rust. They could handle a whole car body. They did my cab. They are no longer here, but maybe there's a facility in your area?
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Sep 2025 Posts: 105 'Bolter | | 'Bolter Joined: Sep 2025 Posts: 105 | What the prior post said, I have an ongoing street rod project (32 Ford pickup) and drove from K.C. Mo. area to Topeka, Ks. to a company that does commercial plating of large industrial objects (light poles and such). They had a dip tank large enough for a car body. I had them do my bed sides to get inside the rolled areas at the bed tops. Very reasonable pricing. Probably something like that around your area within driving distance. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I found a 1 3/4" diameter pipe brush at Grainger for $15. I'll give that a go, then treat it with ospho and run the brush back through after 24 hours to clean up the chalky residue from the chemical process. I will then go to the blaster and have it epoxy primed and painted.
