8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible),
159
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2022 Posts: 21 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 21 | I have a pin hole leak in bottom of oil pan that I can weld up, but there is a bunch of rust pitting in bottom of pan. I have used por15 tank sealer with success on fuel tanks, but has anyone on here used this on an oil pan?
53 chevy 3100
| | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | I had some minor pitting near the drain plug on my oil pan, none all the way thru. I sandblasted the area and filled the pits with JB Weld. Have never used POR15 tank sealer on anything. I don't think that a gas tank that needs to be sealed should be used at all.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Just cut the bottom out of the pan with a cutoff disc in an angle grinder and weld in a piece of 16 gauge mild steel sheet metal to replace it. (NOT galvanized!) www.ebay.com/itm/116195691101?I use an acetylene torch for that kind of repair- - - - -bolt the pan to a core block to prevent warping it while you're welding. Jerry
