1 members (Southerntruck), 98 guests, and 6 robots.
Topics128,266
Posts1,058,386
Members48,485
#1594091 12/12/2025 7:34 PM
I have a 6 volt starter on my '54 235 that I received from a fellow Stovebolter.
The starter was working for the previous owner when it was removed from service and then sat on a shelf for quite a while.
I see a flip-top oiling access point on the forward end of the starter and want to know if I should bother adding some oil. If I should, what and how much do I add?
Basic, but, better to ask than to wish I had.
Thanks!
Nick
1940 KC Model 1/2 Ton Pickup Project
(with '37-'39 Bed and what we think is a '42-'46 Frame)
Taos, New Mexico
The shop manual says to add 30 wt oil, if I remember right. Whatever you put in the crankcase will be fine. Just a small amount. A few drops to keep the felt wet. 1/4 tsp? 1/2 tsp? No need to fill it all the way to the top of the tube.
1950 Chevrolet 3100 (Ol' Roy)
Thanks, Otto!
I couldn't find a reference to lubricating the starter in the Motors Manual that I have.
Nick
Taos, New Mexico
Ok, I actually got out the manual and read it.
Starting motor: "Lubricate every 1000 miles with a few drops of light oil or engine oil."
Generator is the same thing: "Every 1000 miles put a few drops of light oil or engine oil in the 2 oil cups."
U
U Offline
I just put a few drops in mine. Good to know I should follow-up every 1000 miles.
~ John in Utah
Here We Go
Follow in his DITY Bay
