0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1593865 12/09/2025 10:24 PM
I
I Offline
I am rebuilding a 1960 235 engine and needing new oil pump pick up assembly as the original is unusable. Does anyone manufacture an aftermarket piece? I have not been able to find one. What have others done when faced with this issue?
53 chevy 3100
IHPWR #1593866 12/09/2025 10:33 PM
V
VEW Offline
V Offline
~ Victor
1957 3100 - moved on
IHPWR #1593871 12/09/2025 11:24 PM
I may have an NOS pick up. Send me a PM if you would. Are you using the 60 pan? One question, and I dont know the answer, is there a difference in the pans or the pick up between truck motors and car motors?
Mike
I fabricate my own pickups from 16 GA steel sheet metal and stainless steel mesh. It's a pretty simple project, using acetylene welding and pop rivets. Of course, I'm using non-standard oil pumps on some of the engines I build. We seldom, if ever ran a stock pump pickup on the round track cars.
I may be able to come up with an oil pickup assembly if you can't come up with one more locally.
I gave the remnants of a 1958 235 engine, including oil pan, pickup, etc to the machine shop that did my machine work. I could check and see if they'd part with it. I need to go talk with them about some injector hold-down bolts I left in my 7.3L when I had them rebuild it for me. Wasn't a big deal as I had spares of those.
It uses a pipe thread into the oil pump and the pickup is pivoted on the bottom end. RockAuto says the 58 and 60 235's use the same oil pump.
Here is what the 59-62 pickup looks like. This one is NOS. 58 is different, and 55-57 are also different.
Mike
Can you post a picture of the one you need? It will help some of us who might be able to provide one.
