5 members (TooMany2count, tclederman, Gray_Ghost, 2 invisible), 85 guests, and 0 robots.
Topics128,132
Posts1,056,386
Members48,441
#1593517 12/05/2025 12:20 AM
Are the 46 front fenders the same on pickups and 1-1/2 trucks? My 46 1-1/2 front drivers side fender is pretty rough so I'm going to look for a replacement and need to know if they are different from the pickup truck ones. If you have a good drivers front fender here in the Northwest for a 1-1/2 ton, let me know as I need one.
Thanks, TWC
1946 1-1/2 ton
There was three different front fenders in 46 and the pickup fender was only used on the pickups.
1946 with WWII 270
The fender will likely bolt on, but the wheel opening gets bigger as the trucks get bigger.
The fender will not bolt on. Bolt holes are located different an the fitment in the running board area is slightly different.
1946 with WWII 270
Thanks. I’ll go over to the swap forum and see if anyone has one they would sell.
1946 1-1/2 ton
