5 members (carbking, Bill Hanlon, ‘37ChevyPU, Steelonsteel, dt235sd), 75 guests, and 1 robot.
Topics128,051
Posts1,055,767
#1593245 12/02/2025 12:59 AM
I replaced the vacuum wiper motor on my 1950 3100 1/2 t w electric years ago. However, is there a kit to install that helps to keep the linkage from popping loose? Has anyone else had problems keeping the them engaged? I have reconnected them several times but they always eventually pop loose. New clips too. I try not to use them anymore than absolutely necessary. They aren't that great anyway. Better replacements?
Ya, the best replacement is RainX.
Your problem is not unique. In this thread - with pictures - a zip tie is used to keep the rod in the grommet.
https://www.stovebolt.com/ubbthread...-vacuum-wiper-switch-rod-connection.html
1950 Chevrolet 3100 (Ol' Roy)
