0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 78 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 78 | I replaced the vacuum wiper motor on my 1950 3100 1/2 t w electric years ago. However, is there a kit to install that helps to keep the linkage from popping loose? Has anyone else had problems keeping the them engaged? I have reconnected them several times but they always eventually pop loose. New clips too. I try not to use them anymore than absolutely necessary. They aren't that great anyway. Better replacements? | | | | | Joined: Oct 2021 Posts: 6,722 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,722 | Ya, the best replacement is RainX. Your problem is not unique. In this thread - with pictures - a zip tie is used to keep the rod in the grommet. https://www.stovebolt.com/ubbthread...-vacuum-wiper-switch-rod-connection.html
1950 Chevrolet 3100 (Ol' Roy)
