6 members (Guitplayer, Gdads51, Gray_Ghost, sron48, MRMEROTH11, 1 invisible), 89 guests, and 0 robots.
Topics128,068
Posts1,055,882
Members48,428
#15929 05/28/2002 5:21 AM
I tore into my son's 270 today. Figured that as long as the balancer, fan, and radiator are out it would be a good time to reseal the timing cover. Guess I'm the last to know that you don't do that without resealing the oil pan too (not to mention inspecing the flywheel and adjusting the tie-rod ends). Any way, I now need a new gasket for the timing cover, a new seal around the crank, and a gasket for the oil pan. While I'm at it I might as well get the valve cover, head, and mainfolds gaskets -- and why not new radiator hoses.
Where do I start -- my local NAPA guy, or mail order, or internet, or do I make them myself or what? The Pep Boys girls and boys just got that deer in the headlights look and kept mumbling "270....270....270....".
While I'm asking questions, does anybody suggest anything else that I should work on as long as I'm accelerating my state of dis-repair wink ?
Sunk in Salt Lake,
jerry
I got a complete gasket set from Patrick's for my 235. They must have them for your engine as well.
54 3100 with 235
62 flatbed dump C60 with 261
#15931 05/28/2002 11:45 AM
Fel-Pro part number
FS7391 S-4
The FS denotes " Full Set " which includes the oil pan and timing cover gaskets that you need. HS is a " Head Set " which only includes the upper gaskets, valve cover, side pan, head gasket, etc.
Fits
228 engine 39-53
236 42-46
248 39-55
270 39-62
There is also another number on the box 30558
Your local parts guy should be able to order Fel-Pro Gaskets..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
Tony, Bill, thanks.
