1 members (ronsway), 185 guests, and 2 robots.
Topics128,167
Posts1,057,019
Members48,458
U
U Offline
I found my old turn signal switch that mounts to the steering column, but I'm thinking about updating to something new. Just looking for suggestions on a new switch that would have a hazard switch built in. What are you guys using out there? Also, has anyone used an American Autowire toggle switch 500148 to run their turn signals? I guess you could hind it at the bottom of the dash to keep the interior looking stock?
Or, I guess I have the option to figure out which wire does what on this old switch and keep it looking old inside the cab.
~ John in Utah
Here We Go
Follow in his DITY Bay
U
U Offline
Update: I continue to research this old Signal-Stat switch and was able to find some wiring diagrams that might help me to figure out what color goes where. I'm going to play with it to see if it still usable.
~ John in Utah
Here We Go
My Signal Stat 900 clone has a built in hazard light function. I think that was the feature added when upgrading from 800 to 900.
I use a toggle switch mounted under the dash, it's has a long lever on it, simple three wire hook up. Mine turns relays on and off. On the '37, the dash is not that far away and reaching the turn signals is easy for me, just have to remember to turn them off.
Take your switch apart and de-rust it and give it a shine, it should come back to life and look pretty good.
U
U Offline
Yes - That is one option I was looking to have. Thanks Bill!
~ John in Utah
Here We Go
U
U Offline
Originally Posted by Joe H
... Take your switch apart and de-rust it and give it a shine, it should come back to life and look pretty good.
That was one of my plans for this morning. Thanks Joe!
~ John in Utah
Here We Go
The old switch looks like it will come back to life like Joe said ,the wiring on it looks like maybe from the mid 50,s
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
U
U Offline
FYI - I was able to find some wiring instructions for this Signal-Stat 800 switch and all the wire colors match up with my switch. I'll need to pick up a 12v flasher.
~ John in Utah
Here We Go
