2 members (MRMEROTH11, JW51), 70 guests, and 2 robots.
Topics128,066
Posts1,055,874
Members48,428
#1592419 11/21/2025 12:28 AM
I am thinking about re-wiring the headlights on my 53, from the drivers side over to the passenger side, and replacing the terminal blocks. Wondering if 14g wire would be the proper guage for the lights.
Previous owner had the wiring ran in-front of the radiator top baffle.
TIA
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
Why use 14ga when you know you won't have any issues with 12ga?
I rewired my headlights a couple years ago (6v) and used 12ga for everything.
1950 Chevrolet 3100 (Ol' Roy)
You should be able to look up a wiring diagram on line old car manuals website and the wire size should be noted on the diagrams.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
14 ga is specified in the manual. I'm a belt and suspenders kind of guy so 12 ga for me.
If your truck has been converted to 12v then 14ga won't be a problem at all.
Otto,
I can definitely use 12g, and considered it, but wondered about 14.
Thanks.
I just looked at your picture. That would annoy me, too.
Yeah, my truck has been swapped over to 12V.
Me being me, I 'd still use 12 ga.
Wire cost is a one time expense- - - - -voltage drop is forever!
Jerry,
How are you? Yes sir, very good point.
Still on the green side of the grass, and enjoying every minute of it while I can!
