1 members (klhansen), 140 guests, and 2 robots.
Topics128,131
Posts1,056,727
Members48,454
#1591005 11/01/2025 7:00 PM
I've had this manifold stashed, thinking it's 55.1 back to ? With the wider inner stud spacing than later model.
BC
1960 C60 pasture art
I tried searching on GMpartswiki, but it's hard to make out the correct numbers 3 vs 8 etc. Got no hits on the various combinations I tried. If you can post the number that might help. That manifold has obviously been modified, with that welded on outlet.
BC - I squinted through my tri-focals and guestimated that casting number to be 3835388. Screenshot below is from a 1957 Chevy MPC. Application list shows fitting 1949 - ALL (Trucks and Pass cars) (excluding D-D and COE) and 1950-53 All - (Trucks and Pass cars) w/216. Casting number applies to GM part number 3691971.
~ Dan
1951 Chevy 3 window 3100
I bought it several years ago, seems to be a good weld job. Thinking it's '55.1 and earlier .
Cast #8835388
BC
Looks like Dan got it. I knew it wouldn't have been 883xxx, as most casting number start at 3, but I misread the 5 as a 6.
Looks like it fits a 216.
Thanks!
P/N 3961971
BC
AD Addict & Tinkerer
Is that welded in outlet for dual exhaust or just a repair/reroute? How about posting a picture of the whole manifold.
Phil
Project Journals
Stovebolt Gallery Forum
Originally Posted by BC59
Thanks!
P/N 3961971
BC - You got the first 9 and 6 flip-flopped. Correct GM# is 3691971 (shown in my 1957 Chevy MPC screenshot above). wink
~ Dan
Welded for dual outlet with functioning heat riser valve.
Will find better pic
BC
More pics
BC
Cylinders 4 and 5 will sure breathe easy!
The correct way, or better way, is to add a baffle at the midway point so half the ports use one pipe, the other half use the add on. But since the add on has a terrible angle, it doesn't flow as well as the factory outlet so the engine still doesn't run any better. Without doing some port work down in the heads, it doesn't matter what manifold you install. Cut that extension off, weld up the hole, and you have a good exhaust manifold again.
