2 members (GrandpasJimmy, dunfire), 64 guests, and 4 robots.
Topics128,194
Posts1,057,263
Members48,466
U
U Offline
Edit by Moderator: I stripped this post and the responses to keep the Project Journal clean and on subject. This post was referencing installation of the locking bead in the rear window, using a special installation tool
Installing my rear window was a struggle. I did not have that special tool and did it with a simple plastic pry tool. Took me about 4 hours.
~ John in Utah
Here We Go
Follow in his DITY Bay
My palm was really sore using that flat ended special tool. It worked though, and I can imagine it would have taken me a lot longer without it. My wife was "helping" and it might have taken me less time without her. not me
What does the little eye in the tool do?
1950 Chevrolet 3100 (Ol' Roy)
The locking strip feeds through the little eye so that as the tool opens the channel the locking strip is fed into place.
Given the advice from this forum I purchased a tool with a large handle (https://i.ebayimg.com/images/g/3vEAAOSwxodgd0JX/s-l1600.webp) and once I got the technic down was able to get my locking strip/window installed in less than 15 minutes. One of learning curve things was removing the extra options for the "eye" piece so that they were not in the way of the tool working as intended.
1949/50 3600 Project
Follow in Project Journals
U
U Offline
I didn't think to use a wrench for the locking strip? Saw this on YouTube. LINK
~ John in Utah
Here We Go
That box wrench trick is pretty cool. The rounded edges of the wrench probably work better than the straight edges that my tool or WICruiser's have. And doesn't everyone have a small set of combination wrenches? I'm not a glove kind of guy, but that probably would have saved my palm. dang
AD Addict & Tinkerer
I bought the chrome locking bead for my truck. I wonder if the wrench trick would nick up the chrome?
Phil
Project Journals
Stovebolt Gallery Forum
The wrench method is how I have always done it.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
No worse than the edges of the flat steel tool I used. Added picture from my Journal thread that UtahYork was referencing.
After installing a few hundred feet of that stuff over the past 50-something years, I'm about to share a little trick that makes it go a LOT smoother. A trick an old body man taught me back in the early 1970's is so intuitive I'm amazed it's not in general use. A water soluble "personal lubricant" (K-Y Jelly, etc.) makes that lock strip slide in slicker than owl snot- - - -and it won't damage paint like Vaseline or brake fluid can!
I also used a bit of personal lubricant to install the horn button onto my bus steering wheel. The old rubber cup had kinda hardened up, so the lube made it slide right into the metal ring.
I also used the personal lubricant on my back window. The flat tool I bought had sharp edges that would damage the chrome strip. I had to round out the tool hole with a die grinder and chainsaw file to get it to not damage the chrome strip. I got the idea from the electricians at work they used stuff called poly water when pulling cable though conduit.
1947 3600 Chevy
The electricians I've worked around called that wire pulling lube "snot". The only drawback to using it is that it's usually only sold in 2-gallon tubs! It's definitely slippery!
