6 members (Tronman, Hotrod Lincoln, Scott, klhansen, 2 invisible), 70 guests, and 1 robot.
Topics128,206
Posts1,057,433
Members48,471
I NEED YOUR THOUGHTS AND SUGGESTIONS. I’ve got a stock 1958 Chevy 3100 with all original equipment , I’ve got an original deluxe heater and original deluxe heater control switch. The wire to ignition switch to the heater switch has an old school inline 20 amp fuse . Every time heater fan motor is switched on, the fuse blows in one minute. Do I have a short circuit, or a fam motor pulling to much power or something else. Where should I start in tracking down the problem and what all and how should I problem solve the issue. Thanks for any advise. Pete
The 1958 TRI-FECTA
Stepside, Fleetside and Cameo
More Fleetside pix
More Cameo pix
More Apache Stepside pix
Sorry stock 1958 283 engine original switch and heater etc
The 1958 TRI-FECTA
More Fleetside pix
More Cameo pix
Bypass the switch and see if the fuse blows. If not, buy a new switch.
1950 Chevrolet 3100 (Ol' Roy)
could be a bad motor. bad wiring. you could add a fuse block.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
T Online: Content
Maybe the motor has dry bushings and it has to work too hard, drawing too much current and blowing the fuse. Also, does it have multiple speeds? If so, the blower motor resistor could be an issue.
You didn't state:
a. if the fan was turning or not
b. if the fuse blows when the fan is only at low speed
c. if the fuse blows at low and medium speed
d. if the fuse only blows at high speed
The fuse blows when the switch is turned on and the fan runs but the fan only blows at one speed kinda low compared to my other 58 truck and doesn’t increase speed as I increase the fan control on switch to a higher speed. The fuse blows after on 30-60 seconds later. Maybe not even that long. Thanku for any suggestions. Pete
The 1958 TRI-FECTA
More Fleetside pix
More Cameo pix
Pete - Since this all involves primarily electrical components, I've move the thread over to the Electrical Bay for further conversation. wink
~ Dan
1951 Chevy 3 window 3100
Where is the motor resistor. Is it replaceable or in motor housing or windage of motor. I’m not experienced in electric motor parts n functions. Thankyou for any suggestions
The 1958 TRI-FECTA
More Fleetside pix
More Cameo pix
Thankyou. Been awhile since I’ve posted. Glad everyone here is still sharing knowledge. Pete
The 1958 TRI-FECTA
More Fleetside pix
More Cameo pix
The stock 58 deluxe heater fan resistors are directly behind the fan switch .
So the fuse blows even if you leave the fan switch in low?
Thank you. I’m thinking LMC may have these. I hope
The 1958 TRI-FECTA
More Fleetside pix
More Cameo pix
