| | | Forums66 Topics128,009 Posts1,055,295 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 113 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 113 | Purchased a set of headers gaskets and was wanting to know if it makes any difference what way you install them to the head/exhaust manifold? You have a shiny side and a rough looking side. In all respect I have always installed them with the rough side going to the cylinder head, but they seem to fit better with the shiny side going to the head and rough side going to the exhaust manifold which even looks better as far as lining up.. What do you think there Bolters? | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 |
Mike
| | | | | Joined: Jan 2022 Posts: 113 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 113 | That is what I have.. I just wanted to make sure the gasket would work eighther way? Shiny side or rough side to yhe the head/ exhaust manifold?? Thank you.. | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | I have always installed them like you do, rough side to head.
Mike
| | | | | Joined: Oct 2021 Posts: 6,686 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,686 | The smooth shiny side should go UP toward exhaust pipes. Felpro's website has a video explaining this.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Dec 2020 Posts: 1,954 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,954 | Remflex is does not matter...It does not matter which side of the Remflex gasket faces the manifold or header, as both sides will perform the same once installed. The texture difference is a result of the manufacturing process and is not an indicator of how the gasket should be installed, according to Remflex Exhaust Gaskets.
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Dec 2024 Posts: 114 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 114 | I'm not familiar with Remflex gaskets, but if an exhaust gasket has a metal face; the metal face goes against the manifold. Most exhaust gasket instructions I've seen state this.
Geoff
1955 2nd Series 3600 235 cid, 4 sp. - Current 1979 Chevy K10 350 cid 4 sp -Sold 1955 2nd Series Wide Window 283 cid 3 sp - Totaled
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Its a one piece graphite gasket, thick but fluffy for lack of a better description. Outstanding for sealing. works for stock manifolds and really helpful with irregularities in the cheap tube 235 headers or the Clifford 235 headers. More expensive than the more familiar three piece set but way way better. Take a look at the link I posted above.
Mike
| | | | | Joined: Jan 2022 Posts: 113 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 113 | I have a set for my 350' chevy and again would like to verify if I can install them either way? The cylinder heads are a set of 492's round port. And earlier I had mentioned they line up better with the shiny side going to the cylinder head. | | |
