5 members (Gdads51, SmalltownTRKGuy, 52Carl, Cosmo, 55shaker), 62 guests, and 0 robots.
Topics128,049
Posts1,055,629
#1347905 02/25/2020 8:11 PM
Picturing a nice looking replacement wood
for flatbed 1960 C20.
So, I did the math. Ipe - being much harder
than oak, would last past my lifetime.
And it's about the same price.
Just need new blades / drill bits ... etc.
Opinions ?
Has anyone done this yet ?
1960 C20 Platform
dbwr #1348058 02/27/2020 7:12 AM
I did an experiment where I replaced the wood side boards of my barbeque with Ipe. It sat out on the weather for several years. One piece split over time even though it was drilled and through bolted. It turned gray but did not rot. It was in the weather for 5 years in Washington State.
dbwr #1348059 02/27/2020 7:14 AM
I used Beach on my 46 bed. Closed grain and very hard as well. It lives indoors though.
dbwr #1348134 02/28/2020 12:56 AM
I say go for it. Ipe is one of the few woods I would use in a truck bed. Common hard woods like Oak, Maple or Beech are only about 1/3 the hardness of Ipe, which is the 13th hardest wood in the world and the 16th heaviest. It will sink in water. The main reason to use it is it's durability to weathering and its rot resistance. You will not have to use any sort of finish on it if you park indoors it will look the same for decades. If you park outdoors it will turn a nice dark grey color (my preferred look for a truck bed) that can be renewed with a pressure wash a quick coat of a Tung Oil type of finish.
The other woods to look at with similar durability (but not as hard or heavy) are Osage Orange and Black Locust. Osage starts out yellow and turns to a medium brown with exposure to UV rays. Black Locust starts out a light brown and darkens with age also.
If the car manufacturers had used these timbers as original equipment, our friends at Mar-K would be only sell sheet metal.
Don't forget to post pictures when your done.
Steve
1946 1/2 ton
dbwr #1349471 03/10/2020 4:46 PM
I am using Cypress, very durable will post a photo when complete
1963 Chevy C-10 Fleetside
1970 C-30 Dump Truck
2025 Silverado High Country 2500 Diesel
2012 Indian Chief Vintage serial #002 motorcycle
1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout
dbwr #1349485 03/10/2020 7:31 PM
Insomniac
Insomniac
Make sure you wear a dust mask with Cypress. Very bad for the lungs.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
dbwr #1352498 03/31/2020 1:19 AM
Can you buy teak wood in lengths that would work in our beds? It's really weather resistant.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
dbwr #1352583 03/31/2020 2:19 PM
Hmmm maybe thats why teak wood is used in boats. I never thought of it b4
Gordon&Fran,
Thank you for your concern. You really got me to thinking because I didn't wear any mask. I did some research and it appears there are many type of wood dust that could harm you. Again, I really appreciate your warning.
Pete
https://www.mountainwoodworker.com/articles/toxic_woods.pdf
dbwr #1377492 09/18/2020 4:48 AM
I've used Ipe on many deck projects, some covered some not. All tongue and groove. It does hold up very well. It needs a light sanding and replacement oil once a year if exposed to constant sun, otherwise it turns a teak-like grey. You can let it go grey if you like that look, and the wood itself will still last. On covered porches that get more shade than sun, you have to sand and oil every two years. It's not that hard of a task and takes a day to do with a palm sander.
Here's the interesting element: it swells with immovable force when regularly soaked and will buckle itself or anything next to it. With T&G deck boards this was a challenge. I took to attaching 1x Ipe boards to the underlying deck joists and then screwed through the tongue of the deck board into that 1x Ipe. Never had a buckle since then on an exposed deck. Covered decks were never a problem as they didn't get nearly as much rain on them.
I don't know if it's a better strategy to leave a lot of room in the boards for your bed to handle the swelling, or to rely on the strength of the metal and bolts to resist the buckling forces. A little bit of water won't cause this problem, the wood does not absorb water quickly, it has to be consistently wet for a long rainy season (winter in San Francisco for example).
dbwr #1588937 10/04/2025 3:00 AM
I'm a woodworker and use Ipe for PNW decks< I wouldn't hesitate.
Gage
1949 GMC 9434 1 Ton Long Bed
dbwr #1589048 10/05/2025 10:33 PM
Considering the vast majority of these trucks are never going to see daily use on a farm, will never see rain or snow, will never be loaded with hundreds of pounds of cargo on a regular basis, and will live a pampered life in a covered garage, does it really matter what kind of wood you make the bed out of?
You could make it out of balsa wood or compressed cardboard and it will outlast you and all of your descendants.
1950 Chevrolet 3100 (Ol' Roy)
dbwr #1589176 10/07/2025 4:19 PM
Otto, it sounds like you need your own project to work on. Maybe a truck with a cardboard bed? wink
dbwr #1589182 10/07/2025 7:58 PM
its the underside that needs the most protection and wood choice use.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
dbwr #1589197 10/08/2025 12:40 AM
I don’t know about that my 54 had new wood in 1988 ,when I changed it this year the wood was cracked and weathered on top but underside was like new The truck had a tonneau cover for a few years but the sun got at the varnish and started the process but underneath like new .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
dbwr #1589199 10/08/2025 12:52 AM
Authorized Pest
Authorized Pest
Gosh, this title was driving me nuts. So I just searched "ipt" and got THIS website --
What is Ipe?
Ipe Wood Decking, also called Brazilian walnut (Pronounced E-Pay), is a beautiful exotic wood from Central and South America. It is hands down the best choice you can make for your new deck. We welcome you to read all about why Ipe should be the material you use for commercial and residential projects. Please do not hesitate to call us if you have any questions. We love to teach people about this amazing wood!
~ Peggy M
1949 Chevrolet 3804
dbwr #1589201 10/08/2025 1:00 AM
each case is different. I use mine daily. Lot of limerock dirt and mud under mine. But it long leaf
southern yellow pine so its holding up well. 8 coats of varnish. Both top and bottom side of mine still look good.
On my panel trucks the underside is worse than inside. But still there. Wood lasted longer than metal in this case
of marine grade plywood.
~ BD.
dbwr #1589367 10/10/2025 12:50 AM
ODSS President
ODSS President
C Online: Content
In college, I had a part time job unloading tractor trailers at UPS. I found out the wood used on the trailer floors was Brazilian hardwood, able to withstand incredible abuse. Flash forward, (ahem), many years later and I found a local selling his used Ipe deck wood. When I showed up in my 1949 half ton he couldn't believe his eyes and he offered the board feet I needed for a very reasonable price. I used a Tung oil blend gifted to me by Grigg, multiple coats with particular attention to the ends.. The finish is absolutely clear grain beautiful, rock hard, and will last for a good while I am told by those who know.
I assisted Tim Welsh from Lexington in milling the boards for the metal wear strips to be slightly proud of the wood. A borrowed Forstner bit was used for the four offset washers.
~ Cosmo
1949 Chevy Half Ton
