1 members (UtahYork),
80
Mod | | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2016 Posts: 57 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 57 | Picturing a nice looking replacement wood for flatbed 1960 C20. So, I did the math. Ipe - being much harder than oak, would last past my lifetime. And it's about the same price. Just need new blades / drill bits ... etc.
Opinions ? Has anyone done this yet ?
1960 C20 Platform
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I did an experiment where I replaced the wood side boards of my barbeque with Ipe. It sat out on the weather for several years. One piece split over time even though it was drilled and through bolted. It turned gray but did not rot. It was in the weather for 5 years in Washington State. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I used Beach on my 46 bed. Closed grain and very hard as well. It lives indoors though. | | | | | Joined: Sep 2015 Posts: 81 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 81 | I say go for it. Ipe is one of the few woods I would use in a truck bed. Common hard woods like Oak, Maple or Beech are only about 1/3 the hardness of Ipe, which is the 13th hardest wood in the world and the 16th heaviest. It will sink in water. The main reason to use it is it's durability to weathering and its rot resistance. You will not have to use any sort of finish on it if you park indoors it will look the same for decades. If you park outdoors it will turn a nice dark grey color (my preferred look for a truck bed) that can be renewed with a pressure wash a quick coat of a Tung Oil type of finish. The other woods to look at with similar durability (but not as hard or heavy) are Osage Orange and Black Locust. Osage starts out yellow and turns to a medium brown with exposure to UV rays. Black Locust starts out a light brown and darkens with age also. If the car manufacturers had used these timbers as original equipment, our friends at Mar-K would be only sell sheet metal.
Don't forget to post pictures when your done.
Steve
1946 1/2 ton
| | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | I am using Cypress, very durable will post a photo when complete 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | Make sure you wear a dust mask with Cypress. Very bad for the lungs.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Can you buy teak wood in lengths that would work in our beds? It's really weather resistant.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | Hmmm maybe thats why teak wood is used in boats. I never thought of it b4 | | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | Gordon&Fran, Thank you for your concern. You really got me to thinking because I didn't wear any mask. I did some research and it appears there are many type of wood dust that could harm you. Again, I really appreciate your warning. Pete https://www.mountainwoodworker.com/articles/toxic_woods.pdf 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Jul 2020 Posts: 148 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 148 | I've used Ipe on many deck projects, some covered some not. All tongue and groove. It does hold up very well. It needs a light sanding and replacement oil once a year if exposed to constant sun, otherwise it turns a teak-like grey. You can let it go grey if you like that look, and the wood itself will still last. On covered porches that get more shade than sun, you have to sand and oil every two years. It's not that hard of a task and takes a day to do with a palm sander.
Here's the interesting element: it swells with immovable force when regularly soaked and will buckle itself or anything next to it. With T&G deck boards this was a challenge. I took to attaching 1x Ipe boards to the underlying deck joists and then screwed through the tongue of the deck board into that 1x Ipe. Never had a buckle since then on an exposed deck. Covered decks were never a problem as they didn't get nearly as much rain on them.
I don't know if it's a better strategy to leave a lot of room in the boards for your bed to handle the swelling, or to rely on the strength of the metal and bolts to resist the buckling forces. A little bit of water won't cause this problem, the wood does not absorb water quickly, it has to be consistently wet for a long rainy season (winter in San Francisco for example). | | | | | Joined: Sep 2025 Posts: 23 'Bolter | | 'Bolter Joined: Sep 2025 Posts: 23 | I'm a woodworker and use Ipe for PNW decks< I wouldn't hesitate.
Gage 1949 GMC 9434 1 Ton Long Bed
| | | | | Joined: Oct 2021 Posts: 6,734 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,734 | Considering the vast majority of these trucks are never going to see daily use on a farm, will never see rain or snow, will never be loaded with hundreds of pounds of cargo on a regular basis, and will live a pampered life in a covered garage, does it really matter what kind of wood you make the bed out of?
You could make it out of balsa wood or compressed cardboard and it will outlast you and all of your descendants.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: May 2015 Posts: 11,027 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,027 | Otto, it sounds like you need your own project to work on. Maybe a truck with a cardboard bed?
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2020 Posts: 1,958 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,958 | its the underside that needs the most protection and wood choice use.
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | I don’t know about that my 54 had new wood in 1988 ,when I changed it this year the wood was cracked and weathered on top but underside was like new The truck had a tonneau cover for a few years but the sun got at the varnish and started the process but underneath like new . | | | | | Joined: Apr 2004 Posts: 5,070 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,070 | Gosh, this title was driving me nuts. So I just searched "ipt" and got THIS website -- What is Ipe?
Ipe Wood Decking, also called Brazilian walnut (Pronounced E-Pay), is a beautiful exotic wood from Central and South America. It is hands down the best choice you can make for your new deck. We welcome you to read all about why Ipe should be the material you use for commercial and residential projects. Please do not hesitate to call us if you have any questions. We love to teach people about this amazing wood!
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Dec 2020 Posts: 1,958 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,958 | each case is different. I use mine daily. Lot of limerock dirt and mud under mine. But it long leaf southern yellow pine so its holding up well. 8 coats of varnish. Both top and bottom side of mine still look good. On my panel trucks the underside is worse than inside. But still there. Wood lasted longer than metal in this case of marine grade plywood.
| | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | In college, I had a part time job unloading tractor trailers at UPS. I found out the wood used on the trailer floors was Brazilian hardwood, able to withstand incredible abuse. Flash forward, (ahem), many years later and I found a local selling his used Ipe deck wood. When I showed up in my 1949 half ton he couldn't believe his eyes and he offered the board feet I needed for a very reasonable price. I used a Tung oil blend gifted to me by Grigg, multiple coats with particular attention to the ends.. The finish is absolutely clear grain beautiful, rock hard, and will last for a good while I am told by those who know. I assisted Tim Welsh from Lexington in milling the boards for the metal wear strips to be slightly proud of the wood. A borrowed Forstner bit was used for the four offset washers.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
