1 members (UtahYork), 128 guests, and 4 robots.
Topics128,186
Posts1,057,318
Members48,469
When was the 216 valve cover with no oil fill cap used? What vehicles and what years? I understand the oil fill was with the breather tube.
1946 and earlier I believe.
I believe Carl is correct. I have an engine that was in a 1946 and it has the oil fill at the top of the breather tube. I don't recall if that had an oil fill on the valve cover or not, but could check that.
[on edit] The valve cover on that engine had an oil fill cap - probably swapped out for a later valve cover.
Here's a pic of the breather tube with the oil fill cap.
My ‘46 with the original engine does not have the oil fill valve cover.
U
U Online: Content
My 216 in my '46 truck had both. I'm using that vent tube on my '60 235.
~ John in Utah
Here We Go
Follow in his DITY Bay
Valve covers by year.
My Blog
Thank you for sharing the valve cover attachment...just what the dr. ordered! Very informative.
LUKE
That valve cover was used on my '50 COE and probably on all the advance design COEs. The valve cover lies just beneath the "doghouse" so the only quick access to add oil is with the breather tube with cap. In fact my truck had a later 235 and the original cover was fitted to the engine for the very same reason.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
If I had a downdraft tube with an oil fill cap on it, I would put a breathe cap on it as an inlet for fresh air for a PVC set up which would draw the fumes out of the engine via a PCV valve in the valve cover. I would of course need to block off the lower end of the downdraft tube.
I realize that this is backwards as to how the original PVC was setup for these engines, but I have always thought that the engineers had it backwards to begin with.
To be fair to the engineers back in the day, there were very few paved roads back when these trucks were new, so the location of a breather cap on a downdraft tube would not be drawing much "fresh" air that close to the dirt roads.
I run mine kinda like that. Motorcycle-style breather clamped to bottom end of draft tube. PCV in the valve cover.
1951 3100
Re PCV:
There is a early 60’s corvette v8 oil fill tube with takeoff that fits perfectly in the bottom of the Stovebolt, giving oil fill and PCV takeoff…
Sorry for the dark pic but look closely it’s there…
Chuck
PCV fill tube
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
