0 members (),
135
Mod | | | Forums66 Topics128,089 Posts1,056,440 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Can anybody give me a good idea of what to look for in a pressure washer? I need opinions on pressures, HP and what not to waste my time on. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | depends entirely on what you expect tthe primary use to be - I've got a small, easily portable electric 1200psi rig that works beautiful for general stuff, aimed mostly at cleaning jobs for my biz [juice mill], it also gets used on the trucks ocassionally, and works for a range of things, but a bit slow for stuff like building siding or concrete drives
Bill | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Well, I've got a 3000psi unit that I bought primarily to clean the concrete tile roof (weird ain't it), the lanai, and driveway. The 3000 psi is fully adjustable down to something like a thousand or so which makes it good for cleaning the boat, dock, and other light jobs. I would spend the extra few bucks and get a HD gasoline powered washer. You will then be able to blast away at whatever you want. My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Jan 2007 Posts: 38 Apprentice | | Apprentice Joined: Jan 2007 Posts: 38 | I agree with Down2sea, I have a 3000PSA unit, mine is driven by a 7.5 HP electric motor, but a gas driven model makes them more portable. I also have the hot water option and wouldn't be without it. Mine runs off 110 and burns either diesel or kerosene. Makes cleanup twice as fast. It is wise to get a variety of tips as no one tip is perfect for everything. I even have a rotary brush unit that works great with hot water and injecting soap. | | | | | Joined: Apr 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 127 | I would definately get a hot water machine. also consider the gallons per minute (gpm) rating. more gpm = faster cleaning. i use a 1500 psi, 1.5 gpm hot water machine to wash my dump truck and although it's considered a small machine, it works extremely well. jeff
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
| | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | Harbor Freight has a pressure washer on sale until March 12th. Four stroke 2.5 HP motor, 1300 PSI and 1.85 gallon per minute output for $199.00. Lowes also has one on sale for $249.00 but I don't remember the specs on it. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Sep 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 55 | Here is my experience of having gone through three pressure washers: 1.Get at least 2700 psi. 2.Two Gal./minute flow rate. 3.Get a Honda engine.Items 1 & 2 will dictate HP 4.Get a CAT pump. Do Not get Italian Pumps. 5.Hot water is a nice feature but not necessary. 6.An injector feature to add cleaner is needed. 7.An adjustable pressure is required if you are doing different surfaces such as wood and cement. 8.Electric pressure washers are extremely limited in both pressure and flow but they are inexpensive. 9.I won't buy at a big box store. The first two washers came from there and neither lasted 20 hr.
Cleaning concrete is a no-no unless you re-seal as it makes the surface rough and allows water to penentrate. The only thing worse is putting rock salt on concrete. I had to be told this at least three times by three different concrete contractors before I believed it but its true.
Jerry | | | | | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 | Jerry...I think you covered it all. Especially, item 4. Greg
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I have gone through several and the 110 volt Karcher brands hold up the best.The problem I have had with the gas powered washers is with the gas today,you have to use them every other day or you wind up with carb problems.I went to an electric chain saw for the same reason.It starts every time provided the cord is plugged in lol.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Sep 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 55 | Robin 58. What I have been told and have observed is that once the sealer is gone from the concrete its open to the elements. Rain/Snow and freezing/thawing will do the damage over time and the top layer of concrete which doesn't have the rock, because it was 'floated' when finished, will flake off and cracks can happen as moisture penentrates and freezes.
I don't think the pressure washer itself does much if any damage other than removing the protective sealer. The obvious fix is to re-seal after cleaning with a pressure washer.
You probably have less of a problem in the deep South because there is not much freezing. Jerry | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "sealer" isn't commonly used on concrete, and if a power washer can damage the surface, it was a poor mix, poorly laid - I live with plenty of freezing, and power wash areas on my concrete receiving area every year - still there where's gas n spark? he'll float the correct answer Bill | | | | | Joined: Sep 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 55 | I'm going to pull out of this one with apologies for getting off topic with concrete power washing. It was just an aside and not germane to the main topic of what power washer to buy. Obviously a bunch of different opinions/observations. Jerry | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I'm on my third PW for home and before that had two that I used commercially. Both of those had CAT pumps and hot water. Great but IMO a little over the top for the average home owner. However I do agree on buying the CAT pump. The 3 I've purchased for home all had the General pump and none have been worth a toot.
Also have to agree with jbinwa about the concrete cleaning issues. It is a sure way to failure when you blow away the cream and expose the aggregate. Just come look at my driveway apron. | | | | | Joined: Apr 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 127 | i don't want to offend anyone but, a cheep pressure washer is just that.i can clean concrete with a garden hose. if you want to clean a greasy grimey old truck hot water is the answer. just my 2 cents!
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I knew a guy who had some real high pressure rig(4500psi IIRC), it would sure take off the top of what appeared to be good concrete. It would flake the top layer right off. Brian | | | | | Joined: Oct 2005 Posts: 4,254 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,254 | It's all about how good or bad the concrete is. The company I work for has over 40 garage facilties. Each with a wash bay, some indoor, some out. All have heated pressure or steam washers. These wash bays have been in use for more than 30 years. None of the concrete sealed. All have smooth surfaces EXCEPT where water leaks have been. Water itself is very abrasive. Dripping in the same place will make the concrete rough. Years of blasting the grease and muck off has not damaged the surface. Blasting the surface is not constantly done although the environment does remain wet for long periods of time. There will be more damage by mechanical means ( dropping heavy objects ) than there will be from the steamer / pressure washers. Concrete quality will vary from town to town, residential to commercial, etc. I can't remember the last time someone checked if the driver watered the batch down or did a slump test for a residential driveway.
But this isn't about concrete, is it. It's about pressure washers. So let's get back on topic and back to the tools.
BTW, for those that mentioned CAT pumps. We have been using those pumps for over 40 years. 3' x 3' units with seperate oilers for our insulator washer trucks. Loud and bullet proof. If CAT's smaller stuff is of the same quality, I don't see how you could go wrong! | | |
