8 members (Wayne67vert, TUTS 59, Hotrod Lincoln, Otto Skorzeny, klhansen, Shaffer's1950, Dragracefan, fonz8261),
172
Mod | | | Forums66 Topics128,165 Posts1,056,992 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 218 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 218 | Who rebuilds steering boxes and door hinges?? Does any members do this kind of work? If not who do you recommend?? I’d like to have my 51 Chevy 1 ton steering box gone through and have new door hinges pins installed in my door hinges. Thanks….joe
Last edited by Gdads51; 10/01/2025 2:32 AM. Reason: edit title for move to best forum
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: May 2015 Posts: 11,139 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,139 | Lares is one outfit that rebuilds steering boxes. I think it has to go thru another vendor who sends them to Lares for rework. But click here for their contact info. I did mine myself, but it was mainly a cleanup and reseal. Jim Carter sells replacement worm shaft and nut assemblies, as well as sector bushings and seals. I also rebuilt my door hinges. A drill press would have been handy for that, but I don't have one. Succeeded anyway. If your hinge pins are seized in the straps that go into the door, it'll be a bit harder, but still do-able if you're reasonably handy. But I'm not in the business of rebuilding them.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2021 Posts: 6,939 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,939 | Lares did a fabulous job on my '76 Ford F-150 steering gear.
That was 10 years or so ago and it was $300. It's probably double that or more today.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Sep 2009 Posts: 5,985 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,985 | Joe - I moved your thread about the steering box rebuild to the best on topic forum. Your question on the door hinges needs to get asked in the Doors sub-forum in the Paint and Body Shop as the best place for that topic.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
