Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
10 members (Otto Skorzeny, Gdads51, Thom75, dt235sd, 2-Ton, wvstovebolt, MTD91, 3 invisible), 90 guests, and 5 robots.
Topics128,290
Posts1,058,554
Members48,491
I have more zippers then a pair of cargo pants
Who rebuilds steering boxes and door hinges??
Does any members do this kind of work?
If not who do you recommend??
I’d like to have my 51 Chevy 1 ton steering box gone through and have new door hinges pins installed in my door hinges.
Thanks….joe
Last edited by Gdads51; 10/01/2025 2:32 AM. Reason: edit title for move to best forum
~ Joe
Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke
Lares is one outfit that rebuilds steering boxes. I think it has to go thru another vendor who sends them to Lares for rework. But click here for their contact info. I did mine myself, but it was mainly a cleanup and reseal. Jim Carter sells replacement worm shaft and nut assemblies, as well as sector bushings and seals.
I also rebuilt my door hinges. A drill press would have been handy for that, but I don't have one. Succeeded anyway. If your hinge pins are seized in the straps that go into the door, it'll be a bit harder, but still do-able if you're reasonably handy. But I'm not in the business of rebuilding them.
O Online: Content
Lares did a fabulous job on my '76 Ford F-150 steering gear.
That was 10 years or so ago and it was $300. It's probably double that or more today.
1950 Chevrolet 3100 (Ol' Roy)
Joe - I moved your thread about the steering box rebuild to the best on topic forum. Your question on the door hinges needs to get asked in the Doors sub-forum in the Paint and Body Shop as the best place for that topic. wink
~ Dan
1951 Chevy 3 window 3100
