4 members (tclederman, Greg_H, WICruiser, Peggy M), 112 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
#1588519 09/28/2025 6:48 PM
I have replaced all the springs on the truck this past winter. The old springs on front had a broken leaf and on right side it was a 9 leaf spring wist no caster shim. Left was 8 with shim. It went straight then but now it pulls to right, slightly. Would putting a larger caster shim on right side help? Tires seem to be wearing okay. Thanks Grady.
1949 3100
Old Blue
I would think that the caster shims should be the same on both sides. I'm also assuming that you replaced the springs with identical ones on each side. An alignment check should let you know what needs to be done.
Yes the new ones are identical. Also installed the shims. It's not a terrible pull but you always have to have your hands on the wheel.
1949 3100
Old Blue
How's your tire inflation? Same on both sides? How about brake adjustment?
Tire inflation is the same, just adjusted brakes. Haven't noticed it during braking. Only when driving down road.
1949 3100
Old Blue
Also just recently installed a new long tie rod and adjusted the alignment.
1949 3100
Old Blue
Swap tires left to right and see if the pull follows the tire.
I found my axle had some wiggle room in the locating holes for the spring pins, and shifting the axle would change the steering wheel location. Yours could be the same, one side could be forward and the other rearward causing the truck to want to go around a corner. Loosen the u-bolts and pull the axle forwards on the side the truck wants to turn to, or pull the opposite back. Rear axle could be the same way, slightly crooked.
Drop a plumb bob from each corner of each axle from the same location and mark the spot on some tape on the floor, measure criss-cross to see if its square, then front to back to see if its even side to side. Be accurate with the plumb bob or you will be chasing your tail for no reason, I've been there before!
King pins all good and tight?
1951 3100
I will try switching tires. The king pins and the rest of steering all seemed tight. Will also do some measuring as suggested and report back. Thanks for all the information.
1949 3100
Old Blue
Just switched tires and it goes straight! You guys are the best! Thanks.
1949 3100
Old Blue
You got off easy on that one, keep an eye on the that tire.
O Online: Content
Ya, I'd put it on the rear. How old are the tires?
1950 Chevrolet 3100 (Ol' Roy)
6 or 8 years. They're in good shape as the truck doesn't get ran much.
1949 3100
Old Blue
