| | | Forums66 Topics128,180 Posts1,057,148 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | Had a super frustrating hour under the truck yesterday evening. Just needed to do some looking at the clutch situation to determine what I might need for parts, and if my rear main needed to be part of the job.
Had a a little frustration getting the clutch cover removed. Not too bad. However, when I was done and wanted to button things back up…that went really bad. Ended up removing the vertical piece, to get enough room to get the “pan” piece slid in place. Can’t for the life of me get the vertical piece back now. Seems like I’m close enough to get bolts started, but they won’t.
I suspect one or more of the following is true:
1) The PO didn’t have the two pieces oriented correctly…which goes first, which goes on top of which.
2) The rear motor mounts have settled to the point that clearances are tighter than they should be.
3) I’m an idiot and dealing with 4 stupid bolts is just beyond my capability.
Thumbed through the shop manual before bed last night. Hoping to find a picture of the cover and how things sit relative to each other or a description of which order they come off and go back on.
Any guidance is appreciated. ‘Twas a very humbling evening.
1951 3100
| | | | | Joined: Feb 2005 Posts: 1,677 'Bolter | | 'Bolter Joined: Feb 2005 Posts: 1,677 | If you believe the mounts have settled, can you just jack up the tranny a little bit to help get some clearance?
~ John in Utah 1946 1/2Ton w/4-speed manual transmission w/1960 235 engineHere We GoFollow in his DITY Bay- If you think about it, it has been one year ago today!
| | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | If you believe the mounts have settled, can you just jack up the tranny a little bit to help get some clearance? Yes, perhaps. But before I do, want to be 100% certain which piece goes on first and such. I ~assume~ the vertical piece isn’t normally removed. That’s how I dimly remember it from a 235 I pulled from a Task force truck in the past.
1951 3100
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | The vertical piece goes in first, two bolts with star washers, like the side cover bolts.
The housing lower cover goes on next. But as a heads up, there were a couple of versions so you want to make sure yours goes with the vertical cover. If there is a mismatch, you will know it as the lower cover will not fit nicely in place.
Mike
| | | | | Joined: Mar 2007 Posts: 3,446 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,446 | I just pulled my clutch assembly apart this past weekend. The lower pan on my'58 has slots for the 2 most rear bolts, the forward ones have just holes. The vertical piece came out last.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Sheet metal parts are not always a precision fit. If you slot the holes a little, nobody will sentence you to 30 days in the electric chair!
| | | | | Joined: May 2015 Posts: 11,159 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,159 | I recall that the lower pan on my '51 has slots on the rear bolts also. Makes it easier to install, with the bolts started in place, then slip the pan in place and install he other two bolts. Hopefully I can avoid the electric chair.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | Sheet metal parts are not always a precision fit. If you slot the holes a little, nobody will sentence you to 30 days in the electric chair! That’s what I ended up doing a few days ago. In a fit of rage. With a step bit. Best I can tell, the parts are just all bent and beat up. Vertical piece wouldn’t go high enough to get holes lined up.
1951 3100
| | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | I have new motor mounts in my 1954 3600, and when I removed the dust cover it was necessary for me to loosen the motor mount bolts and jack/ lift the rear of the motor up using a jack under the transmission. In my case the excess rubber on the motor mounts was the issue but I can see how "settling" can cause a problem.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | |
