| | | Forums66 Topics128,166 Posts1,057,092 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 1,381 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,381 | I am using the original headlight system on my 37 and a bulb went out and could not find any for 12 volts only 6 volt,well the Filling Station has LED bulbs so I ordered a pair and will report back on how they do. Its getting original tail lights too also with LEDs and maybe it can be seen from the rear better and maybe I can see better out the front too. | | | | | Joined: Oct 2021 Posts: 6,945 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,945 | If you're doing any restoration on the taillights, paint the inside of the reflectors white. They will reflect a lot more light than bare metal or silver.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2000 Posts: 5,233 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,233 | Be sure to change out the flasher unit, it will take a electronic type with the low amp LED's. | | | | | Joined: Feb 2003 Posts: 1,381 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,381 | Bulbs are in and will see how they do at night. | | | | | Joined: Feb 2003 Posts: 1,381 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,381 | In the dark of the garage those lights look much brighter. | | |
