7 members (Bill Hanlon, Otto Skorzeny, 52Carl, Hotrod Lincoln, TooMany2count, chemanic, 1 invisible), 96 guests, and 2 robots.
Topics128,135
Posts1,056,418
Members48,441
#1587475 09/16/2025 12:50 AM
On a long drive over the weekend, truck developed a bit of a whine/ hum in the engine bay. Ain’t much in the engine bay so I figure it’s the water pump or the generator. I did fiddle with belt tension and oiled the generator. Didn’t seem to make much difference.
Seems like it’d more likely be generator. Water pumps seem to growl more than whine, in my experience. I can think of a few ways I might go about pinpointing….screwdriver as a stethoscope, remove belt and feel/ listen as I manually turn…
Before I waste an hour scratching my head, thought I’d get some input.
1951 3100
O Online: Content
When Ol' Roy developed a new noise - squeaking/whine - I assumed it to be the water pump. It had just been replaced and the noise didn't exist prior.
Well, it turned out to be the generator. During Ol' Roy's overheating episode, the generator got wet with coolant. I don't know if rust had started somewhere or what but it didn't affect the charging or anything and after about 6 months or so, the whining went away on it's own.
1950 Chevrolet 3100 (Ol' Roy)
I did flush the coolant this past week. I’m sure it got wet.
1951 3100
Here I thought you were talking about a teenager...
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
If generator has a bearing going out, would I be able to “feel” any roughness or play if I turn by hand with the belt removed?
1951 3100
Maybe, use the long screw driver to you ear first.
B Online: Content
... and if the bearings are in really good shape you might be able to feel or hear the brushes on the commutator.
I like to use a piece of vacuum hose. It is somewhat easier to reach down and around things to listen to it.
I’ve got one of the actual mechanic stethoscope things but I don’t like it all that much. Almost too sensitive and loud.
1951 3100
