2 members (baldeagle, Tony292),
43
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 113 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 113 | A friend of mine is talking about cutting and heating up a couple of engine brackets for his 1957 chevy truck with a 327' chevy engine. Now he asked me by heating the brackets would that take the strength out of them. He doesn't know what these 2 brackets originally went to. | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | Only if they were heated red hot would the strength be affected.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Well I guess he is heating to bend. Most times that will take red hot. But we don't really know what he is doing with what thickness. It's an iffy question.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2022 Posts: 113 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 113 | The brackets are a good 1/4" thick. So I would say yes he has had to really heat these here brackets to make them work? I told him just to go down and by the correct brackets for his project and he basically refuses. I will admit he is very good at metal forming, he is retired from the iron workers union for 37 years. But aren't engine brackets heat treated? | | | | | Joined: Feb 2000 Posts: 5,190 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,190 | No, heat treating would make them brittle, all they need to do is hold the engine up, the rubber portion will control the torque and vibration. You couldn't heat them enough to make them so soft they won't hold an engine. | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | Low carbon steel (which is what the engine mount brackets are likely made of) can be heated red hot multiple times without really affecting strength, except that a little of the surface might flake off each time they're heated/cooled. Low carbon steel really can't be heat treated either, it takes a higher carbon content to harden steel, and high carbon steel can be tempered afterward to remove brittleness.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Didn't Forrest Gump's Mama have something to say about people like that? (and it didn't have anything to do with a box of chocolates!) When I encounter someone with the attitude that "My mind is made up- - - -don't confuse me with facts", I usually let them learn the hard way. Jerry
