Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
5 members (Tiny, Wayne67vert, Dragsix, 1955 1 Series, Otto Skorzeny), 560 guests, and 1 robot.
Topics126,776
Posts1,039,258
Members48,100
Most Online2,175
Jul 21st, 2025
Does anyone know of any around?
Truckrolet - If you are in the hunt for one (seems likely wink ), this post needs to get moved over to the Truck Parts Wanted forum for folks to offer help and suggestions.
Let me know and I'll move it over. smile
~ Dan
1951 Chevy 3 window 3100
What are you putting it in?
I just sold my '56 LCF w/ Powermatic with a spare trans to go with it...they are very hard to find here on the East Coast.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1956 8400 Wrecker w/Holmes 525
1956 9200 Tractor w/Allison Automatic
1952 Willys M38 Army Jeep
1953 Willys M38A1 Fire Jeep
1978 Jeep CJ-5 Navy Jeep
1984 Jeep CJ7
Hughesville, MD
Mike B smile
Any I have found are always to far away. And the one close was when there was a family emergency so. And that was some years ago.
I bet parts are harder to find.
written and edited on the 10th not the 9th?
So your looking, but hoping to find one locally. thumbs_up
I've moved the thread to the Truck Part Wanted forum with a little tweak of your title to help folks see and know what you seek. smile
Best of luck in your search. wink
~ Dan
O Online: Content
There's a company that specializes in shipping engines and transmissions. I've used them in the past and thought a couple hundred bucks to ship a 1000 lb engine and tranny combo from Plymouth , Michigan to Atlanta, Ga was pretty reasonable.
I'll try to locate the contact information if you want.
Parts for antique automatics can usually be sourced from Fatsco , Northwest Transmission or Dave Edwards at .
Automatic transmission parts for all makes and models including Hydramatic and Jetaway
Fatsco Transmission Parts
337 ChangeBridge Road
PO Box 635
Pine Brook, NJ 07058
(973)227-2487 or (800) 524-0485
http://www.fatsco.com/index.htm
Transmission parts for Hydramatic, etc
Northwest Transmission Parts
13500 US Route 62
Winchester, Ohio 45697
937-442-2811
http://99.152.162.116/nwtparts/
Automatic transmission parts 40s –60s, rebuild kits
Automatic Transmission Parts
David Edwards
56 Dale Street, Dept. A
Needham Heights, MA 02494-1218
781-449-2065
http://www.autotran.us/
1950 Chevrolet 3100 (Ol' Roy)
1939 Packard Standard Eight Coupe (The Phantom) | 1956 Cadillac Coupe de Ville (The Bismarck) | 1956 Cadillac Sixty Special Fleetwood (The Godfather) | 1966 Oldsmobile Toronado (The Purple Knif) | 1966 Ford Mustang (Little Red) | 1964 Ford Galaxie 500 coupe | 1979 Ford F-100 | 1976 Ford F-150 (Big Red) | 1995 Ford F-150 (Newt)
Good info thanks. Funny that Northwest trans parts is not in the northwest though.
It's Northwest of Winchester, OH though.
Are you just needing the trans, or do you need the shift tower and retarder pedal linkage also?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Hughesville, MD
In a truck someday.
In a truck someday.
You really need to find a complete truck or a good donor, as sourcing all the little parts one piece at a time will be painful. If you go LCF then even the front sheet metal (upper & lower grille panels and grille bar) are different to accommodate the trans cooler which sits on front of the radiator.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Hughesville, MD
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.093s Queries: 14 (0.031s) Memory: 0.6449 MB (Peak: 0.7359 MB) Data Comp: Zlib Server Time: 2025-09-22 00:41:02 UTC
Valid HTML 5 and Valid CSS
