BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
0 members (),
525
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,270 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Feb 2011 Posts: 1,329 'Bolter | 'Bolter Joined: Feb 2011 Posts: 1,329 | Does anyone know of any around?
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | Joined: Sep 2009 Posts: 4,392 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 4,392 | Truckrolet - If you are in the hunt for one (seems likely  ), this post needs to get moved over to the Truck Parts Wanted forum for folks to offer help and suggestions. Let me know and I'll move it over.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | Joined: Mar 2004 Posts: 6,189 'Bolter | 'Bolter Joined: Mar 2004 Posts: 6,189 | Does anyone know of any around? What are you putting it in? I just sold my '56 LCF w/ Powermatic with a spare trans to go with it...they are very hard to find here on the East Coast. Mike B  | | | | Joined: Feb 2011 Posts: 1,329 'Bolter | 'Bolter Joined: Feb 2011 Posts: 1,329 | Does anyone know of any around? What are you putting it in? I just sold my '56 LCF w/ Powermatic with a spare trans to go with it...they are very hard to find here on the East Coast. Mike B  Any I have found are always to far away. And the one close was when there was a family emergency so. And that was some years ago. I bet parts are harder to find. written and edited on the 10th not the 9th?
| | | | Joined: Sep 2009 Posts: 4,392 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 4,392 | So your looking, but hoping to find one locally.  I've moved the thread to the Truck Part Wanted forum with a little tweak of your title to help folks see and know what you seek.  Best of luck in your search.
| | | | Joined: Oct 2021 Posts: 5,684 'Bolter | 'Bolter Joined: Oct 2021 Posts: 5,684 | Any I have found are always to far away. And the one close was when there was a family emergency so. And that was some years ago.
written and edited on the 10th not the 9th? There's a company that specializes in shipping engines and transmissions. I've used them in the past and thought a couple hundred bucks to ship a 1000 lb engine and tranny combo from Plymouth , Michigan to Atlanta, Ga was pretty reasonable. I'll try to locate the contact information if you want. Parts for antique automatics can usually be sourced from Fatsco , Northwest Transmission or Dave Edwards at . Automatic transmission parts for all makes and models including Hydramatic and Jetaway Fatsco Transmission Parts 337 ChangeBridge Road PO Box 635 Pine Brook, NJ 07058 (973)227-2487 or (800) 524-0485 http://www.fatsco.com/index.htmTransmission parts for Hydramatic, etc Northwest Transmission Parts 13500 US Route 62 Winchester, Ohio 45697 937-442-2811 http://99.152.162.116/nwtparts/Automatic transmission parts 40s –60s, rebuild kits Automatic Transmission Parts David Edwards 56 Dale Street, Dept. A Needham Heights, MA 02494-1218 781-449-2065 http://www.autotran.us/
1950 Chevrolet 3100 (Ol' Roy) 1939 Packard Standard Eight Coupe (The Phantom) | 1956 Cadillac Coupe de Ville (The Bismarck) | 1956 Cadillac Sixty Special Fleetwood (The Godfather) | 1966 Oldsmobile Toronado (The Purple Knif) | 1966 Ford Mustang (Little Red) | 1964 Ford Galaxie 500 coupe | 1979 Ford F-100 | 1976 Ford F-150 (Big Red) | 1995 Ford F-150 (Newt)
| | | | Joined: Feb 2011 Posts: 1,329 'Bolter | 'Bolter Joined: Feb 2011 Posts: 1,329 | Good info thanks. Funny that Northwest trans parts is not in the northwest though.
| | | | Joined: May 2015 Posts: 9,830 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 9,830 | Good info thanks. Funny that Northwest trans parts is not in the northwest though. It's Northwest of Winchester, OH though.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | Joined: Mar 2004 Posts: 6,189 'Bolter | 'Bolter Joined: Mar 2004 Posts: 6,189 | Are you just needing the trans, or do you need the shift tower and retarder pedal linkage also? What are you putting it in? Mike B  | | | | Joined: Feb 2011 Posts: 1,329 'Bolter | 'Bolter Joined: Feb 2011 Posts: 1,329 |
| | | | Joined: Mar 2004 Posts: 6,189 'Bolter | 'Bolter Joined: Mar 2004 Posts: 6,189 | You really need to find a complete truck or a good donor, as sourcing all the little parts one piece at a time will be painful. If you go LCF then even the front sheet metal (upper & lower grille panels and grille bar) are different to accommodate the trans cooler which sits on front of the radiator. Mike B  . | | |
