2 members (baldeagle, 1 invisible),
42
0
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | The PO of my truck left some info with the paperwork about the paint used. I have tried to look it up but haven't been successful. Any help decoding this would be appreciated -
PPG
Exterior - RCDSO WB-139 BRK-B
Interior - TR-MZ TP/PS R
I purchased the truck in 2003. The truck is red with white grill/bumpers. I'm pretty sure he told me it was the same color as a 1999 Viper? Been too long, memory fades.
Thank you for your time.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Sep 2009 Posts: 5,764 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,764 | jmoore - PPG is probably going to be you best source/go to for answers on your paint mix info. One thing I recall is many of the paint companies in the early/mid 2000's revised their paint mixes due to chemical and pigment changes/restrictions and the resulting colors didn't turn out the same after conversion. Here's a link to PPG 73840 1999 Viper Red. It doesn' seem to match up with any of your paint data above.  Hope you can find the answers you seek.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | A good resource for paint codes is www.paintref.com[on edit] Dan’s link takes you there. It even goes back to our old trucks and may show alternate codes for the old PPG codes. Unfortunately it doesn’t have any info on original interior paint colors.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
