| | | Forums66 Topics128,134 Posts1,056,402 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 12 'Bolter | | 'Bolter Joined: May 2016 Posts: 12 | Looking for hints on removing speedometer and fixing or replacing needle. Videos would be appreciated. Thanks! | | | | | Joined: Oct 2021 Posts: 6,831 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,831 | Getting tools behind the dash to remove the 4 nuts holding the speedo in place is tricky. On pre 1954 trucks you can remove the radio speaker grill to gain better access.
When re-installing the speedo, used knurled nuts instead of hex nuts. You can spin them on with your fingers. It's a lot easier.
The bezel comes off by bending a few tabs with a small screw driver. The needle can be put back on the tiny shaft with patience. It's a press fit. They sell new needles if necessary.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Sep 2009 Posts: 5,918 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,918 | timm1960 - This AD Speedometer Freshening thread from a little while back has a ton of info related to speedometer removal, repairs/maintenance to the unit including stuff on replacing the needle. I couldn't find a specific video demonstrating needle replacement. Perhaps another Bolter has a link to one they can share? Hope the above linked thread offers sone needed help.  BTW - Your topic best fits in the Interiors forum, so your thread has been moved there.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
