5 members (5 Window 9434, JW51, Ponchogl, Mike Roache, Charles in CA), 66 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
Disassembled the driveshaft and pinion gear assembly and got a little ahead of myself. Following the devestechnet.com procedures, I forgot to mark the orientation of the pinion shaft retainer to the front pinion bearing. According to deves the retainer has a a special taper to it so the orientation matters. Does anyone know which way the taper faces, towards the front bearing or away from it? Appreciate any help.
Ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
Check here. The pins on the housing push the front pinion bearing forward.
klhansen, thanks. So I interpret that picture, and your description, to mean that the taper should face AWAY from the front pinion bearing.
bigedpa - You are understanding correctly. wink
~ Dan
1951 Chevy 3 window 3100
If you look closely on the retainer you should see we’re the 3 tapered bolts push on it ,there should be marks on the retainer.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
U
U Offline
When I removed mine, it looked like this.
~ John in Utah
Here We Go
Follow in his DITY Bay
U
U Offline
That's how I knew someone took mine apart before me. It had six marks on the retainer.
~ John in Utah
Here We Go
Thank you gentlemen. All great information.
While on the topic of assembly, did you freeze the pinion gear and or warm the bearing to aid in pressing the bearings on the pinion shaft?
Bigedpa
I’ve read and plan on following those instructions on doing a gear change in mine to the 3:55 ratio. Are you doing the same gear change? Are you doing the work on the rear end while it’s still in the vehicle? Did you buy the rebuild kit or buying separate parts based on the list? Please keep us updated on any other challenges you come across.
U
U Offline
Originally Posted by bigedpa
... While on the topic of assembly, did you freeze the pinion gear and or warm the bearing to aid in pressing the bearings on the pinion shaft?
I used a press and did not have to freeze/warm the bearing.
~ John in Utah
Here We Go
