5 members (Gdads51, TUTS 59, RIcckvolt, FAST55, Sedgewick), 51 guests, and 3 robots.
Topics128,229
Posts1,057,804
Members48,477
Page 8 of 9 1 2 3 4 5 6 7 8 9
Got the old seal out... Made In USA 5565J part#. No references I can find.
1 1/2 in for the tube and 2 1/2 for the inner flange
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
BD - The original output shaft oil seal is listed in the 1957 Chevy Master Parts Book as GM# 8612229 with a 1-1/2" ID and a 2-3/8" OD (measured at the external section that presses into the tail shaft housing opening).
There are a few NOS seals offered on ebay, but a modern reproduction/replacement is offered as Filling Station # GR-573. The reproduction has a slightly larger outer flat face flange that serves as the seal into housing stop.
The 1957 Chevy Master parts book lists the same seal as fitting both the standard 3 speed (Parts Group 4.318) and OD 3 speed (Parts Group 4.460) output shafts under that part number.
I tried cross referencing your "5565J" number and didn't get any hits at all. Perhaps an old replacement stock manufacturer that is no longer in business???
~ Dan
1951 Chevy 3 window 3100
National 9613S Oil Seal thanks Dan. Here it is.
I`d guess the 5565J is the original seal
~ BD.
Originally Posted by klhansen
I pulled the engine on my '51 with the transmission in place, but I used an engine leveler bolted to the valve cover bolts. That's not an option on your 235 however.
The 55.2 shop manual I have says remove the engine and transmission together, using eyebolts in place of two cylinder head bolts, but it doesn't specify which ones. The 47-51 Shop Manual says use the third bolt from the rear on the left side and the 4th from the rear on the right side of the head (but the picture attached shows the right side farther forward than that - like between cylinders 2 and 3). You may have to experiment with lifting points without the transmission hanging on the rear. Maybe move forward one bolt hole on each side.
I`ll get some lifting eye bolts. A bar to hook chains up to and a center lift I can borrow.
Picker I have.
Are saying I cannot use the valve cover 3/8 bolt hole w/ the eye bolts to lift it out with?
~ BD.
Do you think these eye bolts in the valve cover bolt holes will be strong enough to lift the engine?
front passenger side + right rear driver staggered.
~ BD.
From what I read searching the ratings on those lifting eyes, they are rated for a working load of 1300 lbs, but I'm not sure that there is enough meat and thread engagement in the valve cover mounting holes to safely support the engine load for lifting. I prefer to remove a couple of head bolts and replace with lifting eye bolts threaded securely into the block like the later 235 shop manuals recommend.
Others with more experience and knowledge should chime in soon.
~ Dan
What I used were the two studs that stick thru the center of the valve cover on a 216.
The four 235 valve cover bolts are 1/4" and would be really sketchy for that task, especially if you were to use a chain between them, which would put quite a bit of side load on them.
Manifold bolts on the driver's side and something else (starter?) on the passenger side with a chain thru them would be stouter than the valve cover bolts.
Or you could use two of the 3/8" bolts holding the rocker shaft on. Maybe a couple of all-thread pieces with coupler nuts to receive your eye bolts, or find some long shank eyebolts [on edit] (third pic added from Grainger.com)[/edit] that would reach thru the rocker stands to the head and thread into it.
My setup was bolted tight to the rocker stands. Here's a couple of pics. I built the leveler out of a trailer tongue jack that had stripped the crank gear.
216 with engine leveler bolted to rocker stand/valve cover studs
Engine leveler
Last edited by klhansen; 08/14/2025 12:17 AM. Reason: added Grainger listing for eyebolts
I see . thanks!
~ BD.
I generally use bolts that are horizontal such as the manifold bolts so I am bending the bolt with lifting force rather than pulling on the threads directly. I locate bolt on each side of the engine, one toward the front, the other side toward the rear and insert bolts through a link on the chain (dictates a heavy chain to get openings large enough).
1949/50 3600 Project
Follow in Project Journals
I`ve done it like that. On this engine the only bolt on the passenger side is the coil mount.
side cover but thats the same bolt size.
~ BD.
AD Addict & Tinkerer
When I pulled my 235, I made a plate out of scrap steel (back of the 216 water pump) and used the coil mount bolts and the manifold bolts. With two bolts it’s plenty strong so I had no issues.
The rope was a fail safe.
Engine lift plate
Phil
Project Journals
Stovebolt Gallery Forum
I like that plate. I have a spreader bar so the chains pull straight up.
With a plate like that Id feel better.
~ BD.
I was inspired. Had this scrap piece of 1/4 steel that just need the one hole drilled. Will work either way to compensate weight
the best I can. I`ll feel better. Better if it was higher than the lifters. This`ll work
~ BD.
and its out!!! slick as a whistle. bellhousing clutch manifold dist fuel pump thermo
flywheel all off. Its at AEC.. advanced engine concepts. Can`t wait!!
i`ll have time to address some firewall issues and paint.
~ BD.
100% thats the one. $4.35 free delivery. National 9613S Oil Seal
~ BD.
Good info to put in the parts info data bank. Thanks for confirming!
~ Dan
Firewall painted and inner fenders attached.
~ BD.
before
~ BD.
Wow. Didn't you say somewhere in one of your first posts on this forum that you'd never done any kind of car repair or restoration before? Maybe I'm misremembering.
In any event, you've done a pretty nice job on these trucks.
1950 Chevrolet 3100 (Ol' Roy)
thanks Otto!! No... no experience. My attention is the original functional detail. and the will to get it done.
What few people that I let see what I`m doing (I get few visitors any how)are amazed at the progress.
It was a definite need from necessity . Nobody would do the work.
Funny with this one..I used a small bottle jack to get the body off the frame. Lookout!!! Thats all I had at the time.
I just learned to weld a year ago. Self taught.
~ BD.
That brow ridge (Roof Filer) patch panel was the first thing I did. Seam separator with the glass out.
Self tapping screws to draw the panel tight and then one at a time back out and welded.
Turned out great.
~ BD.
Then the floor. I had to dissect what was offered. Cab floor. Pics!!
There actually more metal under the wood than original.
~ BD.
Good chance to show the grounding I have. Never too many grounds.
What you see is the braided wire going to the old frame ground bolt thru to the new floor to frame.
In case thats not enough a ground battery lead from there to the upper ground bolt behind the battery.
Thats in case there is not a good ground in my floor replacement. To ground the dash /cab.
Of course the starter has ground going to the battery but in case thats not enough because of whatever reason, I have another
battery ground wire going from the frame to the draft tube mount bolt at the block. The braided wire acts like a washer for both.
~ BD.
I liked the look . 1958 got the same. 3/4 flooring. I think since this one had been converted with
cabinets inside as a remodeling truck. Kept both wheel wells free of dents and paint loss.
~ BD.
~ BD.
Going great. Engine performs fine. Out and driving.
~ BD.
Looks great, glad the engine is working for you.
Hey thanks. I`ll be driving this. The heater I put in works very good. Towards winter more aggressive mud/snow tires and as
long as the roads are dry. I fix em to use em. Its just me and you only live once.
I`ll work this truck and get it thru the paces and decide which maybe to sell next year. MPG matters to me, not go fast.
My 327`s get 12 maybe 13mpg. If I can get 20 mpg out of the 235 its a keeper. This truck has my DNA all over it. Took me
4 years to get to this point with this one. But its cool. All original cept the 3 speed floor shift.
Feels funny w/ the 18 inch steering wheel . But you need it with manual.
I like the Grey, blue /black and chrome combination. Probably paint it a lighter gun metal grey or confederate grey. But I still have some
body work and sanding to do. That final stuff, I just don`t have the eye for.
Heater installed great with no leaks. The original heater I`ll flip to defrost.
~ BD.
Seats and dash. Heater pull cable and vent pull cable. Lower left.
~ BD.
I`m proud to say but not without cussing a great deal , that I rebuilt/cleaned an old DIST and swapped it out with another
old one w/o losing timing. I guess the gear down there is a helix type and will rotate clockwise once the DIST is removed.
Screwdriver and turning the gear back . Took a few times to get it to drop in where I had it marked. Usually one tooth off either way.
The old one wobbled a bit. Engine purrs. Got all the power I need. 2nd oil change soon. I`ll use Valvoline racing oil. 10w30.
Getting cool enough to use the heater and that thing throws out some warm air. Using the stock heater just for defrost. It was 45 this morning.
Tighten the gear in the steering box. Really nice. Like new feeling. Put on a magna flow muffler. New doughnut.
What a feeling driving this thing sold to me as yard art around town.
~ BD.
Really smooth. Plenty of power. Not much has changed from the look of the engine from last year.
It has my newly rebuilt painted black DIST. Leather boot around the clutch fork. Clutch +throttle spring pulling from
a double eyelet piece at the oil pan.
~ BD.
Throttle rod spring and clutch + DIST
~ BD.
Pics!!
~ BD.
NICE!!
You should feel proud of yourself considering the journey you’ve taken restoring this yard art relic. Great job!
Phil
Project Journals
thanks! truck is fun to drive with that 1st gear low. Just moves along smooth in idle on the dirt roads, coming in the driveway,etc.
Worked on the steering stops today and got them loose and working. Adjusted where the tire would not hit the pitman.
Should have over 1000 miles before winter on the rebuilt engine. Amazing the power it has.
I`ll be rerouting the exhaust dump to line up with the frame and bumper bolts. It is in the way when you open the back door.
I admittedly had to bump the idle up so I could know the engine was running at the one stoplight in town.
Soon we will do a rocker adjustment cause we set those slightly loose for the break-in. Its an honor to have Dan Timm helping me.
I`m learning. The best thing I found and used recently is that Sears Dwell/Tach old school meter. Belonged to my dad and I forgot I had it. One like this....
~ BD.
I have one of those that was given to me for my birthday by my mom when I was 16.
I have one as well but haven't used it in many years.
Coinky-dinkly, I just had mine out and used it on Ol' Roy a couple days ago to set the idle rpm after it went up after the valve lash adjustment.
nice to have. you can set the gap with a feeler gauge but the dwell will tell you more.
27-32 for dwell. I have mine at 30.
Got the upper flywheel cover cleaned painted and installed. That closes that final open gap in the BH.
All I had was black paint.
SS ALT spacer . Got rid of the rolled steel.
~ BD.
Moderated by  Phak1
