5 members (Forty9, Hanks custodian, 78buckshot, Pre '68 Dave, 55shaker), 129 guests, and 8 robots.
Topics128,077
Posts1,056,031
Members48,433
#1586348 09/01/2025 1:04 AM
I have a couple of spare SM420s that I'm putting into storage. Both got a little water in them at some point. I just drained what was in them and refilled with a GL4 140wt oil, but for long term storage is there something better? I tried searching for "pickling" and "storing" transmissions, but didn't find much. Lots written about storing engines, but not transmissions.
If you got all the water out, that gear oil should be just fine. No real difference between storage and use, although with use, it might warm up enough to evaporate a small amount of moisture.
You've probably already done so, but I'd recommend you rotate the input shaft , in each gear, to get all the gears covered in oil.
Ron - - Dusty53
1954 Chevy 3604
Ron,
That's a good idea for I have a spare SM420 out in my garage which has been sitting under my garage stairs for quite a few years. Time to pull it out and rotate the gears.
Craig
Insomniac
Insomniac
You might try taking the top cover off and spraying fogging oil in to protect the gears. Should last indefinitely.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Gord,
Thanks for the idea. Something I should consider.
Craig
I you over fill it as far as you can there will be less air inside to produce condensation and all of the gears will be submerged in oil, no need to rotate.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B - If you overfill it, won't there possibly be leakage, at least from the input shaft end? Not sure what you mean by "as far as you can"??? Many/most of the SM420s didn't have full seals on the input shaft, just the "slinger" set up which is going to at least allow seepage until the oil level falls below the bottom of the input shaft.
Another suggestion for long term storage is to seal the shift tower. I've actually packed the shifter ball top and tower opening with grease and then covered with plastic wrap and rubber bands. Leaving this open to the air, even in an enclosed storage, still allows for moist air to get inside the top of the transmission and eventual condensation and rust forming. It can significantly affect the shift tower components over time. This is for really long term storage or if there's potential for leaks in your storage space from rain and what not. dang
~ Dan
1951 Chevy 3 window 3100
Gdads51 #1587093 09/11/2025 2:39 AM
You'd have to get creative and seal the input shaft with some Plumbers Putty or electricians Duct Seal to try and keep the lube in the trans...note, I've never done this, but it seems doable to me smile
Or, you could sink it in a 55 gallon drum full of used motor oil...set the trans on a brick in the bottom so any water that gets in is down below the trans...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B #1587377 09/14/2025 8:58 PM
Originally Posted by Mike B
[quote=Gdads51]
Mike B smile
I'm not a fan of using used motor oil for preventing rust, there can be acids and such in it. As a kid I used it for awhile as chain lube in a chainsaw and it corroded the oil tank.
PapaDisco #1587383 09/14/2025 10:14 PM
I did spin the input shaft but did not run it through the gears, but good suggestion to do so.
The other downside to deliberately overfilling with transmission oil is that is the most persistently stinky fluid ever invented! ;-P Even a tiny drip somewhere will follow you around forever. I'll take my chances with rust instead! :-D
